Ok, this problem of idle drop down to 200/300rpms, when approaching a stop, and then rpm goes back to normal, or the sx engine will stall, is a common situation with a lot of different cars. I picked this one up on internet.
It happens a lot with s13's and with s13's even with sr20 motors and with KA's
The most common advice is the AAC Valve. Clean it ! Replace it! That is the common answer/advice.
But that is not really to say it resolves the problem.
I have removed the AAC valve. And the problem still persists. If the AAC valve is the culprit, then VC 's sx should experience the same problem(cause he is running without the AAC valve too).
On the moment, my sx is idling perfect via the TB butterfly. All idling crap is removed and AAC valved removed too as mentioned.
Now: This is the other advice from internet:
1.Air trapped in air coolant???
2.Vacuum leak
3.Cleaning the TB
4.Feul filter
5.Throttel cable settings
6.clutch switch???
7.Clogged or dirty injectors
8.TPS
9.AFM
10. Engine temp sensor
And no one on internet has come back and said prominently that this or that was the solution to it. Nothing.
I feel the one about the dirty injector/s is getting my attention?
And of course, it all boils down to elimination again.
Chem
