300zx calipers. 26mm or 30mm?
So I have the opportunity to buy either of these two sets of front calipers.
What are the differences? Will I be limited in terms of discs if I ended up with the 26mm ones??
Ok auction just ended.
Got the 30mm ones (sandblasted) incl. hardware for $155. I hope that is not expensive.....
The 26mm ones went for $130.
I guess rears will be a must now to avoid the car being tail happy under hard braking. How many different rear calipers are there and which are the ones to get?
I'd prefer something that uses the discs for the handbrake too and not the internal drum like the stock sx.
What site was the auction on?? That is fair price to pay for them, any idea how much shipping will be??
As far as I know all the Z32 rear calipers were the same, the same as Subaru WRX. The Z32 rear disc will work with our handbrake system but only 280mm or something. I will probably get a set made when I get the calipers, I would like to go 320mm at the rear because my fronts are 330mm. That will give an almost even brake distribution which I will compensate with a brake bias valve.
- n1smo200sx
 - 0.5 Bar Boost
That was a good price.I paid 350 dollars for all four and the shipping was 80 dollars .Then the import duties was R800! The guy  with the red SX didn't organise the rear discs-he paid hard cash for them!!!!
I'm still looking for rebuild kits for the rears but this how it will look like when it's fitted...droooool!!!
						yes the rear calipers do fit onto the stock mounting locations.
only problem is that the original discs are way too small.
you need to buy original 300zx discs, or discs like we got, so that the dics actually goes all the way into the caliper.
you also need a set of custom brake lines.
