S/Steel or Aluminium IC Piping?
Doctor G
0.7 Bar Boost
Post by Doctor G »
So what are the pro's and cons of either IC piping type?
mario_200sx
Post by mario_200sx »
I cant think of any major pros or cons.
Exept that ali does tend to corrode if you dont clean it on a reg basis.
SS i think is gona work you out a pretty penny!
Ali you also need to concentrate on what grade will work the best. For your cold pipe you will prob need a grade to repel the heat the best.
Thats what I think, can be wrong!!!
Rolling Thunder..........
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Ali piping is the better choice, but very few places can make up sets since welding Ali is bit more difficult than SS...
SS is heavy
SS heat soaks
SS is cheaper than Ali
SS can be make up by most exhaust places, they buy mandrel bends and just weld it up.
Even with those cons of SS i'm fairly happy with my SS setup.
Hairdresser MX5
mario_200sx
I always thought SS was more expensive than ali??
Doctor G
0.7 Bar Boost
Post by Doctor G »
My pro for SS was that it's easier to weld on a flange for say a BOV.
The con was it's heavier than Ali.
Cost wise it's the same cause I'm buying a kit from other side the pond. So the shipping on the SS kit will be higher. But it does look like the better quality kit of the two I'm considering.
Well, since this is not a drag car I shouldn't worry too much about weight I guess and just go with the SS. The stock piping is also steel so it cancels out some of the weight at least.
Thanks for the responses.
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Doctor G wrote:My pro for SS was that it's easier to weld on a flange for say a BOV.
Yeah just be aware that SS FMIC kits from abroad has paper thin piping from what I've heard they are also a bitch to weld flanges on for BOV's. On the other hand since they are paper thin, they are not that heavy... Ask Gary he has an import IC kit, so does someone else with an S14.
Hairdresser MX5
mario_200sx wrote:Exept that ali does tend to corrode if you dont clean it on a reg basis.
huh? are you sure you have the right metal in mind???
mario_200sx
YES I DO!
WE HAD LOADS OF ALI ON OUR RACING CARS AND TRUST ME, IT DOES CORRODE....
I WAS THE ONE ON THE SHORT END POLISHING ALL THE ALI THE WHOLE TIME!! :evil:
widowmaker
Real Name: Walter
Post by widowmaker »
and if it corrodes from the inside? then you have funny stuff going through your engine... :shock:
mario_200sx
I dont even wana think about that!!!
Doctor G
0.7 Bar Boost
Post by Doctor G »
Now I'm happy I went SS....
As for the Ali corroding. It must be a poor grade of aluminium.
thats what i was thinking.
yes ali corrodes, but its nothing compared to mild steel, iron, etc!!! a little bit of fine white powder on some aluminium is nothing compared to the holes that develop on cars that live at the coast!!!
