HOWZIT GUYS!
GOT A QUESTION!
HOW DO I GO ABOUT TURNING A CA18 DE (NON TURBO) AUTOMATIC ENGINE INTO A LOW BOOST TURBO MACHINE FOR ANOTHER APPLICATION.
I KNOW ALL THE ENGINE COMPONENTS ARE THE SAME AS THE CA18DET TURBO SO THE MANIFOLD & TURBO SHOULD FIT BUT FROM A TECHNICAL SIDE, WHAT SHOULD I LOOK OUT FOR AS THIS IS AN AUTOMATIC MACHINE & THE MANAGEMENT SYSTM IS DIFFERENT.
YOUR INPUT PLEASE!!!!!
dont critic my engine stand, it works!
Damn thats oily! but not as bad as my beemer motor
It should be simple but can be tricky, the Exhaust manifold from a turbo shoud bolt on, I'd recommend the ECU and wiring harnas from a turbo'd car, and turf the auto box and get a manual and flywheel.
One thing is compression, the NA motor will be in the 9.5 - 10 bracket, the turbo is 8.5 so definately a low boost setup with such a high compression ratio.
All in all it might require some effort, it might be easier just to sell this motor and get a CA18DET as the NA might be missing bits that you need. That one also looks like it needs a rebuild....
Thats true, and someone once mentioned something about oil squirter's as well, but I can't confirm... But yes you are actually looking at a full rebuild, new pistons for low compression, in that case one can just as well rebuild the engine.
Even with a compression as low as 0.3 bar you are looking at problems, the piston on that engine goes into the head, even at low boost you'll be blowing gaskets or have a potential knock problem.
forget these other clowns. low compression is for sissies.
i say take that stock motor and give it half a bar and see what happens. stuff should bolt on so it shouldnt be a big deal. find a 2nd hand ECU and you're in.
just remember - clean that engine first. its rather filthy!
