Thanks for the advice Ero. I was ready to burn the bitch today ("You like fuel that much? Well how do you like it now, bitch??"
) Four years of leaking injectors, even after spending R10000 to fix it, is enough to drive any man insane. Especially one as short tempered as me.
Took the bloody fuel rail off 6 times! Each time I put the fracker back in, there'd be a little fountain or a stream. Even before I started the bloody car. Tried everything - different injectors, different o-rings, rubber tape, plumber's thread tape. I was ready to give up but the last combination of injector, o-ring and thread tape seems to have done the trick for now.
I say "for now", because this is a temporary fix. I have mis-matched injectors, altho they seem to flow the same and hence the engine is smooth. Also the thread tape might get eaten by the fuel, but at least not as badly as the rubber tape. My gawd, have you guys seen what happens to rubber tape in fuel? It MELTS! Right before your eyes
Plus I can see these other injectors are getting a little damp up atop, even though there is no leak now.
I just hope it lasts a few months while I find an alternative solution to this problem, which will no doubt involve brand new injectors, probably 440cc.
Damn, I almost didn't think I'd make it tomorrow...
