Project D - 1 DEC 2007
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
hehe 27th motor is going back in! (if all goes as planned) we drop motor in, start it and braai! :lol:
Store room cleaned... off to stripping the rest... :wink:
Hairdresser MX5
Ero_sennin
Post by Ero_sennin »
Vlade wrote:hehe 27th motor is going back in! (if all goes as planned) we drop motor in, start it and braai! :lol:
Good Luck! Had to do some work this morning as well, reattaching a boost pipe. Stupid boost pipe. :roll:
SONY Xplod inside
SR20DET Powered Red RS13
i remember the very 1st time one of my boost pipes decided 2 climb off during a run.
I thought my engine blew up :oops:
Ero_sennin
Daniel wrote:i remember the very 1st time one of my boost pipes decided 2 climb off during a run.
It was fine on the way to my destination, lekker boosting. Left there when I was done, much later, drove fine and when I finally decided to floor it after a while I felt fokkol turbo. I was thinking, for fark sakes what's broken now. I'm glad it was just the pipe. :D
SONY Xplod inside
hey vlade,
nice work there mate!
hope it all goes well this time.
i also pulled CA18det this weekend. twice!!! LOL - i mean that i removed two CA's and gearboxes (also spilt oil, cos i couldnt get a drain plug out!!!) from two sx's this weekend, and rebuilt my mates beetle's brakes. its been a busy weekend.
now to some parts/systems (PS, alternator, injectors, belts, turbos, etc) transplants, and then on the 27th it can all go back in!!!
so sorry broo, cant join the spanner'n'braai!!! would've enjoyed it though!!!
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Hah cool busy CA weekend it seemed
Any way, achieved my goals that I had yesterday. Motor stripped... This is what I found.
some glazing that occurring, 1st sign of worn rings
this time i'm changing this bugger, PS any one got a oil pickup for me?
motor shots
Parts all over, not my cleanest work, but I'll worry about that when putting it back together
can clearly see the glazing happing here
Block went to engineers this morning, I'll probably get the verdict by the afternoon, know if I should rebore or it can just be honed.
Question: Don't know if anyone will be able to help me with this, on ARP studs you get a lube with it that you apply to the threads, I don't have any of that lube lying around, what else can I use?
Update: from my interweb research tool ie. Google.
Torque 25ft/lb, 50ft/lb, 80ft/lb. using a 30w oil, the torque increases when you don't use Moly Lube that ARP Supplies... Since it a 30w oil has more friction coefficient than the moly lube that comes with the studs.... Interesting... Even more interesting apply at least 5 fasting and loosening before applying final torque. That from ARP's site.
Hairdresser MX5
johansx
Post by johansx »
Vlade, what oil where you using for the run in?
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Shell Mineral oil.... (yellow bottle) think it glazed because of the richness... I've had a motor glaze like that before but it was because i ran it under constant load to Bloem (my 1st try, was rather dumb)
Hairdresser MX5
Sokar
1.0 Bar Boost
Post by Sokar »
Ouch!
Those pitons look browner than Phinx's motor, and he's done 170000kms!!!
Also that head looks a little dry? or is it just me?
Anyone up for a trip? I know a big Island off the coast of New Zealand I'd like to "visit"
VC I now you're with me!!!!
Captain Slow to the rescue!
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Sokar wrote:Also that head looks a little dry? or is it just me?
ummm by the cams or by the valves? Sorry sme little confused?
Hairdresser MX5
Sokar
1.0 Bar Boost
Post by Sokar »
Vlade wrote: Image
On this pic, the cam looks a bit dry and the "drip" area below it....?
Ya true sokar....I am no expert but that does not look normal....may this not be part of your problem Vlade....a reason why....
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Draco wrote:Ya true sokar....I am no expert but that does not look normal....may this not be part of your problem Vlade....a reason why....
Here I already removed the engine, and before that it stood for 2 weeks... So that the reason it dry, don't worry it was soaked before that
Hairdresser MX5
johansx
Post by johansx »
Sorry for maybe sounding a bit dumb, but too much fuel will wash the oil from the cylinders, causing massive wear. This is not apparent from the honing marks.
You either have a combination of warn valve guides or valve stem seals, or your compression rings are upside down. Looking at the combustion chambers and the top of the pistons, that thing pumped oil up, not down. Maybe it is just 1 of the 2 rings that are upside down. Can you perhaps post a close up of on if the pistons where the rings are pulled out of the grooves?
ps. I've donned my flame proof undies :wink:
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Took some hi-res pics will post tomorrow my USB cable is at work.
Here is what I found in the SK site
Hairdresser MX5
