TRACKDAY AT ZWARTKOPS:
If it is the o rings on the injectors I can help you with that Toby....Toby wrote:Cool beans! Maybe u can gimme some tipsVlade wrote:I'll shotgun with youToby wrote:Yes I am planning to put mine on the track, but as you know, mine's standard![]()
My Baby won't be there... she is getting a tune/fix upAnd also hold the fire extinguisher that I'm going to buy, 'cos those goddamn injectors won't stop leaking
- Toby
- Club Founder
- Real Name: Toby Kurien
Shot Draco, that might help! I think it might be o-rings. The leak is slight, but still, need to get it fixed. Only 2 injectors are leaking - let me know if you got 2 spare O-rings - I was thinking of getting slightly thicker o-rings and jam the sucker in, 'cos I'm sick and tired of leaking o-rings
IIRC toyota 4AGE injectors have similar o-rings that you could use.
they'll be about a 250th of the nissan price, but just take your part with you just to make sure.
i might be talking about the big rubber thingy on the top of the injector, or i might be talking about the o-ring, but i'm just not sure at the moment!
the mazda rotary injectors are the same, and they might be a 50th of the nissan price!
- Real Name: Bruno
Cool babnanas, man so i'll join you okes then.
Hey toby i've seen in some of these drag cars(the KAK ones and good ones) with that red silicone thing around injectors to stop leakedges give it a try, or you can buy my RC 550cc injectors brand new
to sort your problem out.
ONCE YOU GO JAP YOU WILL NEVA GO BACK
- Nissan 200SX S13 SR20DET 1992
Nissan 200SX S13 RB25 1994
Nissan Maxima 3.0L V6 1999
Honda Accord 2.4 Exc 2005
Toyota Hilux 3.0L D4D 2011
- Toby
- Club Founder
Thanks bruno, but 550cc injectors would give me bigger problems (so to speak) - ecu re-map and all that! Silicone around the injectors... dunno if they can stop 3 bar fuel pressure! But at the mo the leak is not too bad so I'm gonna risk it! Besides the Vlademaster will be there to douse the flames should the need arise.. hehe. But I'll get those o-rings from you Draco, and fit them. Believe me I know how - have swapped injectors 6 times already. And I did buy a set of o-rings from Nissan once, cost R26 for 4. I just hope it's the o-rings and not the injectors themselves. Otherwise, you guys might have to call me Ghostriderbruno_miranda26 wrote:Cool babnanas, man so i'll join you okes then.
Hey toby i've seen in some of these drag cars(the KAK ones and good ones) with that red silicone thing around injectors to stop leakedges give it a try, or you can buy my RC 550cc injectors brand newto sort your problem out.
One day when I'm big I may be interested in those injectors....bruno_miranda26 wrote:Cool babnanas, man so i'll join you okes then.
Run run....here is chemical grumpy....his gonna ban us....calm down toppie...we just chatting and all
You would have made a cool onnie
