radiator cap
radiator cap
im sure there is a post some where but browsing is a problem. just a quick one: what is the preasure rating on the radiator cap? i can't find anything in the manual and mine needs replacing. is it ok if i buy a temp from a shell garrage or something?
200SX Catch my DRIFT?
A 1.3 bar radiator cap will reduce operating temperatures in your engine and is a great performance add on. If you're running a higher pressure on your cooling system it helps keep the temperature down on the entire system, by raising the boiling point of the coolant. This will help during hot operating conditions like running the air conditioning while climbing hills, long road trips, bumper to bumper traffic, and high performance track or strip driving. It's especially helpful if you live in a warm climate. got it from the box of a NISMO CAP
scintifics
Oooo ok, it makes sense, in a way, well if the box says it you can trust it.
maybe i make this more technical. does higher preassure not cause more friction between molicules and a higher temp? or does this only apply to a gas and not a fluid. im thinking that the higher preasure cause as a higher flow rate so there will be more circulation through the radiator and a higher cooling rate.
Ok so now all of a sudden my water is emptying itself through the expansion tank. i recently replaced the radiator cap and the highest i could get is 15 psi which is almost 1.1 bar. (the big cap, not the small ones like on the stock radioator) i cant find the previous one to compare
my question is when it heats up it goes in to the expansion tank, but when it cools down, it doesn't 'vacume' the water back in to the system from the expansion tank like its suposed to
- johansx
- 0.4 Bar Boost
- Car: S14
Leak in your system, either the pipe outside is sucking air, or the inside system sucks air. Since the water goes to the bottle outside, my guess is that the pipe sucking back from the reservoir is leaking. Probably where it fits on to the radiator side.
