Weight reduction S14
S14RB25
Post by S14RB25 »
Please help me, I want to do some weight reduction. But keep in mind I dont want a race stripped car (maybe at a later stage)
So far I have removed sparewheel, radio and speakers.
My goal is to dip into the 12sec on the quatermile. (@ 1bar boost as it will cost me another R8000 before I can turn the boost up as they recon my injectors are leaning out at 1.1 bar.
Take out the aircon pump, back bumper inside....take out the big metal bar, same with the front, take bonet and both front fenders off and take it to a fibre glass guy to mold and match paint.....thats about as far as you can go without starting to strip oem parts inside....
WooHaa
0.6 Bar Boost
Post by WooHaa »
You can cut out sections of the metal bumper reinforcing. I'm not sure what you call it, but it's the metal backing BEHIND the bumper.
You can also take out the sound deadening material under the bonnet.
And that's all I can think off.
Steer From the Rear !!
S14RB25
Post by S14RB25 »
Tnx ill start with the fibeglass bits would love if I could get spare fenders and bonnet to use as molds.
jap spec
Post by jap spec »
Stephan has spare fenders and a bonnet actually....I would start with taking the sound deadning and rubberiser under the carpets out, the carpets in teh boot, front bar behind the bumper and maybe the back.... after this its the carpets, roof lining, etc....the fenders might be good idea but make sure you take it to a guy that knows his shit otherwise its just gonna look worse....this would maybe be a chance to look at wide body front fenders and in frp......i know creative rides, bryce can hook you up with them(origin).... As for dipping into the 12's, that sounds awesome.... What kind of power are you making, about 250kw on the wheels or what? I have an RB running at 0.6 bar with 200 on the wheels... let me know, im keen to get mine to hook up...is your stock with a cooler?
S13 - everything
something and something else
S14RB25
Post by S14RB25 »
Im making at this moment 300kw @ 1bar boost.
Ran a 13.5 @ 180 at Brakpan(unprepared track)
jap spec
Post by jap spec »
thats obviously 300kw on the flywheel? im running 245kw on the fly, and a bud is running a gt3040r on his and getting 345kw at 1.55 bar...
is it flywheel with standard turbo?
S13 - everything
I speak under correction, as far as I know that is on the wheels.....
jap spec
Post by jap spec »
whatever it is is serious...the reason i ask wheels or not is because Rezlo's car made teh 345kw at the fly, which is about 260 on the wheels....somethings either wrong there or something.....ifs its 300kw on teh wheels, i cant wait to sort out mine then
S13 - everything
Whell I for one is not surprised, a RB 25 engine with the works will make that power easily, the last dyno sheet I saw it was well over 300kw's, I think it was around the 360 mark if I am not mistaken but that was with 1.5 boost or higher...can't remember....
S14RB25
Post by S14RB25 »
That is 300 @ the wheels (manny marino's dyno)
I made 360 @1.3 bar boost but on the dynopack (hub dyno)
Since then changed the turbo housing so that we could get the turbo spooling up sooner.
dwayne
Post by dwayne »
nice power figure
GOING SOME WHERE FAST!!!!!!! :-)
S14RB25
Post by S14RB25 »
tnx dwane are you going to race next week Sunday?
Or this comming Friday?
dwayne
Post by dwayne »
i would like to if i can get my brakes and shocks sorted. you dont have by chance a pic of the front and rear pads of the s14?
jap spec
Post by jap spec »
OK, it was on the doctors dyno, jerry called me when it was on the dyno... something happened though if i recall? anyway, those figures aint bad at all....mine is stock at the mo, but i'll sort it soon....what turbo and internals you running?
S13 - everything
