My S13 CA18DET only cranks and cranks. There are fuel, spark ,compression and cas checked out 100%.
This happend before and went checking everything and for some reason it started and ran about a month now again same issue.
never knowing what caused the engine not to fire.
I have not done the Self Diagnostics test yet.
Is it possible that it is flooding so much that it does not start.
Maybe it is the cold start valve or Coolant temperature sensor playing up.
Any other imput is greatly appreciated
