I can have a look at that weird dump valve setup and check the wastegate etc for u when injectors back in and car running, maybe I can see something wrong there
Over fueling or Injectors or Something else
- Real Name: Jaco
Re: Over fueling or Injectors or Something else
That would be very awesome and much appreciated!!troopiec wrote:I can have a look at that weird dump valve setup and check the wastegate etc for u when injectors back in and car running, maybe I can see something wrong there
Ex: 1985 Alfa GTV 2.0
Ex: 1981 Alfa GTV 2.0
Ex: 1989 Honda Ballade 160i DOHC
Ex: 1991 Honda CRX
Ex: 1997 Honda RVF 400
Ex: 2007 Yamaha R6
Current: 1991 Nissan 200sx
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
- Real Name: Jaco
Injectors in, wiring sorted and new connectors fitted. Car started up last night
Took it for a spin, still have an irregular idle and running rich. So at this point I can confirm it was not injectors, but at least the fuel leak have been fixed!!
I think Nissan_Fanatic theory is spot on and that's the reason for overfueling. Troopiec, it will be great if you can have a look at my setup, when you have time of course
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Sure il check out Nissan fanatics theory when I check out your car sounds very Plausible, PM me your cell number we can arrange something via Whatsapp
100% the problem the ecu accounts for that air that is lost and delivers more fuel
- Real Name: Jaco
I sent a mail, the forum dont want me to send pm'stroopiec wrote:Sure il check out Nissan fanatics theory when I check out your car sounds very Plausible, PM me your cell number we can arrange something via Whatsapp
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
]I sent a mail, the forum dont want me to send pm's
Sorry should be sorted now
- Real Name: Jaco
SonOfAnarchy ZA wrote:]I sent a mail, the forum dont want me to send pm's
Thank you !!
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
- Real Name: Jaco
Ok, update.
Installed another set injectors. Replaced the fuel pressure regulator and some hoses.
The oil doesn't smell to bad, it ruff idle's from time to time. I'm 90% sure the waste gate is not welded, but still have to confirm full operation.
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
