Wie se geld het jy gesteel??? Lyk goed man, lekker bou!!!
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Hahaha, as ek jou se sal jy weet waar het ek die Kruger punte opgegrawe.
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
https://www.youtube.com/watch?v=Nl_vM8mN7xk
Just a quick video of the car running and fooling around, was just fooling around. Car limits at just over 6000rpm with 0.5 bar boost...
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Hi Guys, so its been a long time since i posted. In the mean time i have rebuild the motor with CP pistons....So here is to the next stage of development
First item is the ID 1000 injectors, i believe they would be super. Will let you guys know how they perform.
- Attachments
- Im changing the 800cc Deutchwerk injectors for ID1000 injectors.
- 20150618_170916.jpg (50.45 KiB) Viewed 112004 times
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
New poly bushes
- Attachments
- 20150618_171150.jpg (111.82 KiB) Viewed 112004 times
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
CA18det solid lifter set
- Attachments
- 20150618_170957.jpg (48.45 KiB) Viewed 112004 times
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Tomei solid lifter cams....270 deg 10.25
Will post a video showing before and after. Maybe get some Idle characteristics in there as well
- Attachments
- 20150618_171106.jpg (58.99 KiB) Viewed 112004 times
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
:-_)
- Attachments
- 20150618_184219.jpg (73.36 KiB) Viewed 112004 times
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
EGT
- Attachments
- 20150618_171352.jpg (57.27 KiB) Viewed 112004 times
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Greddy electronic boost controller
- Attachments
- 20150618_171317.jpg (46.7 KiB) Viewed 112004 times
Lekka list of goodies
now get it in and done so we can see what power the car makes
Nice to see another crazy person building a CA. Keen to see how the cams work.
Nice Sir, looking forward to the results, hope the cams does not shoot the lag up more.
if anything those cams should spool the turbo sooner but will make the car lazy low down but then again who drives their car there
Will have to see, those cams are there to increase top end power, I believe the turbo will come in very aggressively but lag will be crazy.
