Occasionally (but happening more and more), my R33 will just lose all power, not Rev past 2000 rpm, not respond to throttle, and sometimes not even idle.
The TPS has been suggested. Anybody have advice on how to diagnose, and where to find replacement?
Thanks
Help with RB26 stuttering issue
Re: Help with RB26 stuttering issue
If it stutters - try giving it a good scare. This is recommended by 8 out of 10 health professionals.
Check for fault codes, much better than randomly diagnosing things.
Also had tps problems. Open it , clean with switch cleaner and spray switch lube into it. Solved my problem on a R33..
Just seen it`s you bud..now I can add, fixed cnutish neighbours car like that.
- GameBoy
- Real Name: Roscoe
Airflow meter? If still on... Unplug and rev to see if any change...
Seems to be AFM. When I unplug them the car does exactly this (limp mode I guess). A
Going to try and solder in case of dry joints. Anybody have some AFMs I could borrow to try?
- GameBoy
- Real Name: Roscoe
Try cleaning it first before opening. Sometimes they just get a little dirty.
I do have a Rb 26 airflow that you can get
Opened the AFMs. Soldered connections. Sorted.
- GameBoy
- Real Name: Roscoe
Awesome stuff!!!
