Hi guys..
I have killed my back tyers and now need to replace them.
Is it possible for me to use 195/50/R15 ? becuase stock the car sould have 195/60/R15.
S13 tyer sizes
S13 tyer sizes
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
63kw - 117nm 1.3- N/A
1993 Nissan 200 SX
1989 Toyota Corrola
Are you guys Sure?
Wont this mess with your speedo and stuff?
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
1993 Nissan 200 SX
1989 Toyota Corrola
Well I got Yokohama on now and I get 20 000km to a set and at R1600 each thats expensive. I went on to www.1010tire.com and was reading the reviews and TOYO came out tops.
Yeah, changing tire size will make such a small difference.
Smaller diameter tires have better acceleration, while bigger ones have higher top end speed. But again, unless you make a BIG change, it won't be noticable.
May the hinges of your generosity never rust, and may a thousand trumpets blow you through the gates of hell!
- widowmaker
- Real Name: Walter
