FRSport Group Buy Sept 2014
- Drillergy
- Real Name: Darryl
Taken off another forum, I'm running the group buy.
Hi guys
Im doing a group buy for our workshop and my 200sx buddies.
I have a dealer account with FRSport. http://www.frsport.com
How it works is the following.
Visit FRSport, find the part you want and link and post it up.
I will quote you.
If you happy, you can confirm the order
You can pay anytime before I put in the order.
In about a months time I put in the order.
Everyone gets paid on a different day.
As more orders come in your part gets cheaper as we split the shipping.
At the final time ordering, if you pull out, everyone elses price goes up, so dont be a douche and commit if you want anything.
Once a week, I will submit a list of items for quoting on a Thursday, so check in on a Friday or Saturday, if you requested prices in that week.
FRSport sells mid to high end JAPANESE car parts. Not the cheap stuff from ebay or Mr Turbo or Turbo Toys.
So happy shopping, guys.
Any questions???, lemme know...
Group buy starts 22nd August and ends 22nd September. Parts will be here mid October. Enough time to get our machines ready for the holidays.
Regards
DARRYL
Hi guys
I will quote you.
Regards
DARRYL
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Re: FRSport Group Buy Sept 2014
Anything happening here?
I want Nismo engine mounts and Steel exhaust manifold gaskets
- Drillergy
- Real Name: Darryl
The only S2k HyperRev issue is #143 and no swaybars in stock.
Part Price
Circuit Sports Nissan S13 Engine Torque Damper Top Mount R 1 250.00
Whiteline Front Engine Mount Nissan S13 SR20DET/KA24 R 1 650.00
Cometic Bore 87mm MLS .066 Nissan SR20DET Inline 4 Metal Head Gasket R 1 200.00
ACL Race Series Nissan 4 SR20DE/DET R 780.00
Circuit Sports Nissan SR20DET Rocker Arm Stopper R 720.00
Nissan OEM water Pump Assembly R 730.00
Greddy GREX SR20 Rocker Arm Stopper R 970.00
Nissan Ornament Display S13 Turbo Charged Intercooler Spark Plug Cover SR20DET R 400.00
Nissan OEM Oil Pump/Timing Cover - S13 SR20DET R 3 200.00
Nissan S13 SR20DET Valve Gasket Cover R 185.00
Nissan OEM Twincam Turbo Intercooler Sticker R 120.00
HyperRev Issue 144 S2000 AP1/AP2 R 350.00
Greddy Timing Belt 1JZ-GTE R 2 100.00
Greddy Timing Belt 2JZ-GTE R 2 100.00
Greddy Timing Belt RB25DET/RB26DETT R 2 050.00
Aeromotive A1000 Injected Bypass EFI Regulator - Adjustable R 2 250.00
AEM 320lph E85 High Flow In-Tank Fuel pump 320lph @43psi Inclides installation kit R 1 650.00
Circuit Sports Nissan S13/S14 240sx Offset Rack Speering Spacer Kit R 1 320.00
Circuit Sports Nissan S13/S14 Inner Tie Rod Set R 700.00
Circuit Sports Nissan S13/S14 Outer Pillow Ball Tie Rod Set w/ anti bump steer R 1 150.00
Circuit Sports Nissan S13/S14 Tension Rods - Castor Adjust R 1 550.00
Aeromotive SS Series Inline Fuel Filter (3/8 NPT) 40 Micron Fabric Element R 1 150.00
Aeromotive Fabric Element 40 micron Replaceement R 250.00
HKS SSQV4 BOV R 4 200.00
Autometer Boost Vac 60 cm/Hg - 2.0 bar mechanical R 1 100.00
Autometer Oil Temp 60-170C R 850.00
Nissan OEM Hood Rod Clip R 50.00
Order so far
Part Price
Order so far
I'm keen for a set of inner tie rods. How much for a set of Tein inner and outer for S13?
Im interested in this set of S13 adjustable tension rods please:
http://www.frsport.com/Megan-Racing-MR- ... _7873.html
![Image](https://dl.dropboxusercontent.com/u/21878969/tension-rods.jpg)
![Image](https://dl.dropboxusercontent.com/u/21878969/s13%20signature.jpg)
- Drillergy
- Real Name: Darryl
Hitroopiec wrote:Im interested in this set of S13 adjustable tension rods please:
We finding issues with the Megan arms.
This is with the tierods camfer.
In my opinion the Circuit Sports are a better option and the price is above.
Just bare in mind that we using it for drifting and we work the steering quite alot and put it through quite alot of abuse, especially when you learning.
If you really like the Megans, I will get you a price on Friday.
The rest of the items I will quote on Friday as per my first email.
Cheers guys.
Hey man I'm willing to go for the best option on that price range, of you say the circuit sports is a better quality product in keen on them, i just can't afford ones such as the Tein, i thought Megan would be better than circuit sports as it's a more well known brand? Also do you know by how many degrees that circuit sport arms can adjust? I knocked a curb and my tension rod support bracket holes pulled a bit off centre and when they poly mounted the new caster rod they also moulded the hole of centre so my caster on the right is at 4.5 degrees and i need to get it around 6 degrees which is standard
Replace the parts you bent rather than fitting a patch job to try and cover up the accident damage.troopiec wrote:Hey man I'm willing to go for the best option on that price range, of you say the circuit sports is a better quality product in keen on them, i just can't afford ones such as the Tein, i thought Megan would be better than circuit sports as it's a more well known brand? Also do you know by how many degrees that circuit sport arms can adjust? I knocked a curb and my tension rod support bracket holes pulled a bit off centre and when they poly mounted the new caster rod they also moulded the hole of centre so my caster on the right is at 4.5 degrees and i need to get it around 6 degrees which is standard
If your mounting points are not in the OE position, the measurement on an alignment machine means f-all. It will still be wrong as the axis and dynamic angle will not be correct.
Bottom line, fix it right or don't bother - you WILL just be throwing your money away
![Image](http://i908.photobucket.com/albums/ac290/Enzio83/random/nyancat.gif)
I replaced all damaged parts of course, but when they poly mounted the new oem caster rod the Bush went off centre by a few mm, it was a small knock i had chassis and all is perfect just the holes for the tension rod bracket infront pulled like 1mm, i took the car to 2 body shops who said itl be fine to go with adjustable as with cars like the older Cressida had aswell so i want to get now anyways to build up fully adjustable in future
- Drillergy
- Real Name: Darryl
Hi
Prices will be up tonight.
Thanks
D
Thanks
D
- Drillergy
- Real Name: Darryl
Hi
Prices are in.
Circuit Sports FLCA-0013-HC FLCA-0013-HC Adjustable Front Lower Control Arm S13 R 5 800.00
ARP 208-4702 Head Stud Kit Undercut Studs 12pt Head Honda S2000 Base 2000-2003 R 2 000.00
Isis IS-SUSPK-NS14 Suspension Arm Package - Nissan S14 240sx Silvia R 7 000.00 - Shipping makes up R1.8k
FRSPORT 1102 Tein Inner & Outer Tie Rods Combo S13 S14 S15 240SX SILVIA R 2 450.00
Tomei 32865S010L Duracon Shift Knob M10 x 1.25mm Long 90mm R 450.00
Prices are in.
Hy Darryl, so i would like to take these circuit sport S13 tension rods as you say they are better than the Megan, heres a screenshot to confirm:
![Image](https://dl.dropboxusercontent.com/u/21878969/s13-circuit-sports-tension.jpg)
and the price on that will be around R1500?
by when would i need to pay you the money?
Thanks
Thanks
- Drillergy
- Real Name: Darryl
Yea those are the ones. Will be ordering soon, probably around the 20th-28th.
