So far i only have a 76mm pipe on my 200sx...
What should be the next mod i do?
Bigger inter cooler? Upgraded Fuel pump?
Next Mod
- rat
- Car: R32
- Real Name: Rat
Re: Next Mod
stock nissan pump are dying at 20yrs+. walbro is a good replacement.
- drift-zn
- Real Name: Alan
Re: Next Mod
Thanks Gary and Rat for your input...
Gary - would a 300x600x76 inter cooler be okay? With say 50mm boost pipes?
Rat - which Walbro pump is the best one to get? The 255?
Re: Next Mod
300x600x76 is perfect. 50mm will be a bit small. Check ebay for the full kits.
I may be bringing in a few FMIC kits if you interested.
- rat
- Car: R32
- Real Name: Rat
Re: Next Mod
63mm hot and 76mm cold pipes. Also depends on future power goals.
- drift-zn
- Real Name: Alan
Re: Next Mod
Gary - I have checked Ebay... There are some really nice FMIC kits available for good prices. Send me more info on the kits u looking at bringing in, I am keen.
Rat - Is 76mm not to big? Will it not cause a lot of lag? Or as long as u keep the pipes short will it be okay?
My current plans for now is keeping the CA and doing GT28RS on low boost ( under a bar ) and maybe later converting to SR20...
- drift-zn
- Real Name: Alan
Re: Next Mod
Thanks for your help guys.
R31skylineguy
- Engine: 1JZ
- Real Name: Alex
Re: Next Mod
Maybe a fuel pressure regulator aswell since you doing the fueling system
