So I'm planning on putting together a small tool kit to leave in the car, in case of emergencies and breakdown etc.
What do you think should be in this kit?
10 spanner
Screw drivers
Pliers
Cable ties
Insulation tape
Flat fix
Please this is a small kit, I am not changing clutches on the side of the road so emergency tools only. Must fit into stock tool bag.
200sx emergency tool kit
Re: 200sx emergency tool kit
I'd say just ad the general spanners, 8, 12,13 and maybe a small allen key set(or the general sizes)
- Real Name: Nat Wakefield
I'd let it comprise of the following:
1. double-sided spanner with 8 and 10 on either side (gedore)
2. double sided spanner with 12 and 14 on either side (gedore)
3. screw driver with flat and philips head - reversable
4. pliers (gedore)
5. 30mm wide x 10m long roll of duct tape (preferably sellotape make from builders)
6. Flat fix (the one in the can that most bikers use)
7. LED torch (small size) or smallish LED light that plugs into lighter socket
8. 1 x pair of latex gloves (nothing worse than changing a tyre, getting your hands dirty and touching everything inside your clean car with dirty hands)
9. cable ties
4. pliers (gedore)
9. cable ties
13 spanner aswellHotstuff wrote:I'd let it comprise of the following:
4. pliers (gedore)
9. cable ties
i keep 4 spare plugs in my sx and obviously a plug socket also brake fluid and 2 fire extinguishers(1kg and 2.5kg)
- widowmaker
- Real Name: Walter
every sx should have a tow strap
can of tyrefix - the marie biscuits are getting old
small shifting spanner
Q20
carb cleaner
I keep a small multitool in the doors of every car anyway
this reminds me to get spare fuses I always forget...
Q20
carb cleaner
Ja spare fuses is a good idea aswellwidowmaker wrote:every sx should have a tow strap![]()
Q20
carb cleaner
- widowmaker
- Real Name: Walter
can you even get replacement marie biscuit tyres? probably heluva expensive
and the guys with updated hubs, brakes, lowering, etc - have you checked that your spare fits at all??
- widowmaker
- Real Name: Walter
like my grandfather would say : "bloudraad en 'n tang"
- Skippy
- 0.2 Bar Boost
- Real Name: Matthew
Time to update the emergency kit
We be like government.... "What emergency, there is no emergency"
