Specs:
- Dark blue 1992 200sx S13 shell with 148000km's
- Licensed for a year
- Full interior in good condition with all stock gauges, speedo and rev counter working
- Bucket seat with adjustable rail
- Deep dish steering wheel
- 4 gauges in center panel, water temp, oil temp and oil pressure need to be wired up but come with all senders and wiring. Boost gauge is hooked up.
- 6x9's in rear shelf (no radio)
- 17" black with polished lip mags and tyres (fronts are new)
- 30mm spacers up front
- Coilovers all round
- New brake pads all round
- CA18 gearbox with new rb25 clutch setup (strong)
- Shimmed Viscous differential (very tight)
- New custom and balanced one piece prop
- RB25DET motor with stock turbo and boost controller (dyno'd at 180 kw and 340 nm) (10.5 bar compression on all 6 cylinders, no smoking, strong motor freshly serviced)
- Walbro 255 lph in tank fuel pump
- Dictator management
- Cone filter
- Front mount intercooler with dump valve
- Large radiator with twin electric fans (custom cooling system, runs cool)
- Full 3" exhaust system with large Jap back box
The car has been fully setup and tested for drifting and everything has been built to keep the car road legal and very reliable on track when going sideways. The car is perfect for anyone starting in drifting or for anyone wanting to take it further with a properly setup and reliable car.
Project thread can be found here:
http://200sx.za.net/phpBB3/viewtopic.php?f=6&t=10482
What the car will need:
- Roadworthy
- Boot for gear lever as box has been moved back
- Aftermarket Gauges wired up
- Custom front say bar to get the best out of the switches in drifting when coming off power (optional). Alternative option is to have the sump modified to mount the stock ARB with new bushes supplied (recommended)
The car is in my name with all paperwork and is ready to go now. It will come with loads of spares that I have gathered up over time and a full set of extra 17's with new tyres is available for the car at R2000 extra.
Any questions or test drives (with me driving) are welcome
info@kaihatsu.co.za
0820912639
