My mint SX
Re: My mint SX
You have PM.
Re: My mint SX
You do realize that swapping a working viscous fan for two electric fans is a downgrade...
Re: My mint SX
Charlvdw wrote:You do realize that swapping a working viscous fan for two electric fans is a downgrade...
Saves space not that you need it but he is 100% right
Twakkie
Re: My mint SX
Post by Twakkie »
How do you come about that? Surely you lose power wielding that dead weight around for no reason? It had to come out in any case there’s not gonna be space for it with a RB fitted, admittedly its taking longer to get there with my Rotary Anglia project chowing all the funds…
Re: My mint SX
the viscous fan pushes more air and with the shroud it is way more efficient and i dont think you gain alot by removing it but if u going rb it wont fit it lol
Re: My mint SX
Twakkie wrote:How do you come about that? Surely you lose power wielding that dead weight around for no reason? It had to come out in any case there’s not gonna be space for it with a RB fitted, admittedly its taking longer to get there with my Rotary Anglia project chowing all the funds…
Well if you going RB.. then ja twin fans are a must, have a look at @ Kyles build for how close the RB sits to the radiator... ( AFAIK - the biggest reason the original Viscous fan works better is mostly down to the plastic radiator airflow surrounds causing cooling when the car is in motion even with the fan pretty much off. )
NB @ Twakkie... Please don't do a budget RB transplant.
Re: My mint SX
If this question is directed at me, the answer would be experience.
I would have started with a decent radiator.
Real Name: ????
Re: My mint SX
Post by Adrian »
dude my 1jzs viscus is not gona fit but thats why im buying a fan that will fit onto my viscus system..
You will gain 1kw if that with the viscus off.. that is not worth it
Twakkie
Re: My mint SX
Post by Twakkie »
That’s probably true, but as i said it was more a space saving exercise then power
Twakkie
Re: My mint SX
Post by Twakkie »
those are old pics tough, couple of things happened since then. i slightly kinda sort of blew my t25, and i was stuck in Bronkhorstspruit so i had to tow her back to PTA.
Took some clever maneuvering to get her on (bit low after the suspension drop)
This was in the back box of the exhaust
so i got a t28 from stallion
up graded the plumbing and inter-cooler etc.
this is the suspension done a while back
theres a couple of other things done as well, will update with pics a bit later.
RB25SX
Re: My mint SX
Post by RB25SX »
Fit a stock RB26DETT :wink:
R32 GTR
Re: My mint SX
nice coil overs!!
Twakkie
Re: My mint SX
Post by Twakkie »
Ja that's the plan. i really want to have a RB26 at the end of the day, even though they are super expensive!! let me show you whats chowing the funds at the moment...
a mother of a bridge port, still got some toy's to be fitted
got the fueling sorted
fitted
old suspension cut out
Intercooler space
and that's why the RB is on the back burner for the moment as the SX is my daily.
