Hey guys been trying to figure out a way to monitor the flow of water meth as i am worried that the pump or boost sensor will fail. I know AEM has the flow gauge but that is expensive and cant afford it at this stage so i need to come up with a new plan.
Would i be possible to plum in an oil pressure gauge to the line in order to tell pressure or will the meth chew it up or not have enough pressure to register a reading?
Any other ideas?
Do you have an AEM water meth system? It has a status LED and boost safe that you wire into your management to safeguard the motor incase anything fails on the system.
John fitted a water /meth flow gauge with all sorts of safety features into the Celica. Would cut high boost when flow was low and all sorts.
Will ask him to come on and expand..
