I have been without a 200SX for too long now, think it is about time to rectify the situation. But before I commit myself to it, I would like to know if my ideas / plans is feasible and attainable. This is where the Brains Trust of this Forum comes in.
1) The VET motor is FWD, and thus not compatible with the S13's RWD layout. Is there a way to modify the motor to fit the S13 chassis? (Mikes Place has two VET's in stock at R18900.00 each) Don't want to buy a VET motor and a DET just to do a head swop.
2) If the VET cannot be fitted to S13, the SL16 / SL20 VVL head fitted to the DET is the next option. Heard that the SL16 is the better head to use, is that so, and why? Are they obtainable here?
3) Would like to stroke the motor to 2.2L by either using the Tomei stroker kit or the HKS kit. HKS advises that you put Cylinder Liners in due to the block being weakened by the machining to fit the larger bore (86.5 or 87mm) pistons. Is this necessary? I would think yes, especialy if you want to build a big HP motor (I would like between 450-500bhp) Obviously all the other bits that goes with this kind of power will be included.
4) Body wise I would like to fit the nose of the S15 to the S13 (hence my nick, 200SX13.5). I love the overall body shape of the S13, the S14 looks too much like an camry
Would you fit the Carbon doors? I see they rate it for "offroad" use only. I want to build the car for mostly track and drag use, but it must still be streetable, so it must be roadworthy.
If money (yeah
