* Minimal Shaft play
* Never Used, Removed from Import W10 SR20DET
* 64 A\R Exhaust
* Part number - 14411-1E001
The T25 housing from the CA18DET should bolt up with no issues.
Custom T28 Ballbearing - R500 onco
*** BROKEN Bearings Collapsed ***
* GT28RS Compressor Wheel
* Balanced by Stallion Turbo's
* 64 A\R Divided Exhaust Housing
* Built from a S15 Ball bearing unit
I used this turbo on my W10, The Compressor wheel has no damaged and Turbo still spins freely , I suspect one of the bearing cartages collapsed as there is a noise, Can be used for Spares the GT28RS compressor cost me R1k to import on its own
I just don’t have the space for the small units anymore as I have a GT2871R on the shelf and GT2876r on the car. The turbo’s are taken as is
