so this is my idea for the fire wall in the back..
gives me just enough space to get the fuel cell. Will be closed up against the boot lid
also played with the bonnet hinges so this is able to happen.
easy acces is a must. these dam s13 are kak to work on with the bonnet in the factory open position
And 1 just because i can!!!!
finally done with cleaning out the seams in the engine bay and inside the car. time for under it!!!
Thanks man..
Yea the hinges being able to open like this is awesome.
Simple to do. Pull the hinges out. Lock them in a vice and cut 1 side of the stoppers out. Will try take pics 2moz of them.
nice job
dude, before you weld those seems. I would recommend running a blow torch over them to burn out the seem sealer in between the seems.
From past experience. The welds look shit and you don’t get proper penetration when the seem sealer contaminates the weld area.
Burn it out. Then run a wire brush over the seems. There after. Welding is so much easier.
On the the s14 and 350z. we encountered the same problem
Booster wrote:nice job
i gave it a test weld and found the same with the seam sealer..
I gave it ago at burning the shit just need to wire brush it now
Any how a big thanks to Barry for organizing me a gear box
Been welding all weekend. Havent welded with tig for some time so im a bit rusty but all is good.
Man what a shit job it is!!!! trying to bend in all these odd places to weld is not fun at all
What ive been busy with at work hahaha i actually had my boss helping me bend the pipes
Man its been a busy week. Get home from work and start to work again..
this is what she is looking like now
Done about 90% of the front tubing. All the body panels and front bumper are lining up nicely.
its looking like a car again.
Chopped out the inner door skins, pulled the glass out and the electric motors.
Last shot to Barry for the directions the other day, found my bends i need
