S14 Front wheel hubs / studs
fuzz123
Real Name: Jacobus
Post by fuzz123 »
Howzit guys,
The previous owner used spacers to get the mags over the front calipers and by doing that greatly reduced the amount of thread available to tie the nuts down. I realized this morning that the left hand side wheel has stripped almost all the studs already.
So I need new front hubs, and if possible I need ones with longer studs on them...
Can anyone please help? Or point me in a direction where I can purchase some... [smilie=200sx_1eye.gif]
So I found these :
http://www.enjukuracing.com/products/AR ... 52d98.html
Stud Specifications:
S13/14 Rear, S13 Front: ARP 100-7708
Thread Size 12mm x 1.50 RH
Knurl Diameter (in.) 0.509 in.
Underhead Length (in) 2.500 in.
Knurl Length (in) 0.315 in.
Quick-Start Nose No
S14 Front : ARP 100-7717
Knurl Diameter (in.) 0.565 in.
Underhead Length (in) 3.000 in.
Knurl Length (in) 0.270 in.
Quick-Start Nose Yes
But they do not ship to SA....does someone know where I can get these locally?
Re: S14 Front wheel hubs / studs
Knock out the studs and put longer ones in. Don't need whole hub unless your wheel bearing has gone.
fuzz123
Real Name: Jacobus
Post by fuzz123 »
rat wrote:Knock out the studs and put longer ones in. Don't need whole hub unless your wheel bearing has gone.
Thanks!
I found the ARP studs,now I just need to find someone that has them in stock & sells them...
I sent an email to turbo direct, they are the only people I know of that sells ARP.
Ichiba does extended studs as well.
fuzz123
Real Name: Jacobus
Post by fuzz123 »
rat wrote:Ichiba does extended studs as well.
Thanks!
So I phoned turbo direct, and they do not have these studs..... they will come back with price and availability... :facepalm:
Are there any other ARP-products distributors that anyone knows of?
fuzz123
Real Name: Jacobus
Post by fuzz123 »
Ok so:
I ended up importing the studs through Turbo Direct, they cost me R741 for 10 studs and it is ARP products so I know the quality is good!
The sad thing is that I still could not find anyone else who is willing to import ARP products for me apart from Turbo Direct.... and I cannot import directly myself.
Anyways, I guess all is well that ends well!!
Reliable Bolt and Nut, Terrace rd , Edenvale. Any stud, bolt in all lengths up to 80mm available, 10mm , 12 ,, 14 and 16mm diameter.
Been buying my wheel bolts and studs from them for years already.
BigKriss wrote:Reliable Bolt and Nut, Terrace rd , Edenvale. Any stud, bolt in all lengths up to 80mm available, 10mm , 12 ,, 14 and 16mm diameter.
Good info thanks
Seems like he wants name brand studs.
fuzz123
Real Name: Jacobus
Post by fuzz123 »
Bleh BK! Why did you only say something now... :facepalm:
I honestly tried everyone and everything I knew...but now I will know for the future. :D
Atleast I know that ARP is very good quality, and that it wont be a waste of money.
rat wrote:Seems like he wants name brand studs.
I would have settled for other brands but I could only find ARP.... :oops:
likwidsoul
Real Name: johnny
Post by likwidsoul »
Can I have the old hubs?
I'm sure it's a five hole.
fuzz123
Real Name: Jacobus
Post by fuzz123 »
likwidsoul wrote:Can I have the old hubs?
Sorry bud, I ended up buying only studs from Reliable bolt and nut....Turbo Direct is so useless that I am still waiting for them to tell me where the studs are.
