The Kaihatsu Silvia in parts
djtreble
Post by djtreble »
Final Konnexion Kit (fully repaired ready for paint) - R5000
4x ROTA Torque 5x114 17x7.5 ET45 with tyres- R6000
Original and rare Silvia Digital Climate Control - R1000
Alternator - R500
Engine that has been rebuilt less than 1000km's ago, built with Arias forged pistons, new oil pump, new chain, new VCT gear, new bearings, custom work to head, redline solid 3mm headgasket, practically a fully blue printed engine. Spent 35k+ on the build of this engine excluding the cost of the engine itself - R17500
60mm Nissan Throttle Body adjusted to fit RWD SR with TPS sensor - R500
ACT Heavy Duty clutch (Needs new clutch plate or re-padding) - R1500
Custom Lightened Flywheel (needs skimming) - R1500
Nistune with ECU and full Silvia wiring loom - R6500
S14 car cover - R400
Stock dumpvalve and intercooler piping - R500
PM me or email me for what you are after.
Thanks
Dylan
info@kaihatsu.co.za
www.rotawheels.co.za
www.kaihatsu.co.za
Rawkus16v
Re: The Kaihatsu Silvia in parts
Post by Rawkus16v »
Put me down for the diff....
MarcoSX
Post by MarcoSX »
Hi Dylan, I will take the rear lights off your hands, I sent you a mail.
and the Coilpacks too please
djtreble
Post by djtreble »
Do you have standard 14 tail lights to send to me?
www.kaihatsu.co.za
MarcoSX
Post by MarcoSX »
Yep I do, they are in my car at the mo....
"6 point bolt in FIA Roll Cage with cage padding - R6000"
"Rear sub frame as well"
Thanks bud..
djtreble
Post by djtreble »
Hi Kriss,
I have reserved the cage for you but I can't sell the rear subframe as the shell is going as a rolling one.
www.kaihatsu.co.za
Ok, that's cool.
Put me up for the 2x headlights and the cage cut dash.
2nd dibbs on the diff. :?
MarcoSX
Post by MarcoSX »
Can I get 2nd dibs on the headlights lol?!
djtreble
Post by djtreble »
Done
www.kaihatsu.co.za
Stephen Swanepoel
Post by Stephen Swanepoel »
Start stripping.....
No ones buying drift cars at the moment. They all think its cheeper to build one up... Ohh how wrong they are.
djtreble
Post by djtreble »
It is looking that way very quickly, just awaiting on a reply from someone who may take the whole shell minus the drive train and the reserved parts.
Speaking of which, do you still have that s14?
www.kaihatsu.co.za
Stephen Swanepoel
I most certainly do. :facepalm:
djtreble
Post by djtreble »
PM sent
www.kaihatsu.co.za
djtreble
Post by djtreble »
Shell is available again
www.kaihatsu.co.za
