throttle position sensor
hi guys the throttle positioning sensor has two different connectors, can anyone help me work out where a wire should go? its on the connector connected directly on the sensor the middle pin it looks like the a cable going to it was cut. i tryed to find the other side of the cable but dont see it anyone have any idea?
- Real Name: Renier
Re: throttle position sensor
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
thanks nizan but my issue is on the wiring side going to that point pin number 2
that green wire were does it go
- Real Name: Renier
check if you have continuity between between pin 3 on that plug and green wire if yes
the plug can be from a auto wiring loom
makes you want to scream finding shit like that
found my s15 afm wiring has been modded
(O=O)/RS13\(O=O)
this car just makes me want to scream!!!! there is no continuity but i do get a 12v reading between 1 and 3
