FPR
FPR
If i get a stronger fuel pump do i need to get a better FPR?
Ero_sennin
Re: FPR
No, Fuel Pressure will go up, unless you really want to get it back down you'll need to get an adjustable one..
SONY Xplod inside
SR20DET Powered Red RS13
Re: FPR
its not going to flood the motor or anything like that?
Re: FPR
iF EVERYTHING IS STANDARD, including boost it will run very rich because you have now ultered the pressure which in tern alters the amount of fuel delivered unless the pressure does not increase exponensialy, depending on how much the FP increases you can compensate by increasing boost.
It should not flood the motor, if you plan to keep everything standard and it is over fueling alot, you need to bring the FP down to standard.
Ero_sennin
Re: FPR
Draco wrote:iF EVERYTHING IS STANDARD, including boost it will run very rich because you have now ultered the pressure which in tern alters the amount of fuel delivered unless the pressure does not increase exponensialy, depending on how much the FP increases you can compensate by increasing boost.
What he said.....
SONY Xplod inside
Re: FPR
okk kwl thanks guys gonna be increasing my boost to a bar so should be fine after it gets on a dyno
