Hi guys probably stupid questions so please be patient got to learn some how.
1. there is a rubber hose going to the fuel return pipe.....What would happen if that had a leak in it?
2. What would happen if one of the cables on the throttle positioning sensor is off?
CA18DET questions
CA18DET questions
Re: CA18DET questions
1. It would leak fuelSonOfAnarchy ZA wrote:Hi guys probably stupid questions so please be patient got to learn some how.
2. It would not know throttle position/not engage idle switch
it doesnt seem to leak fuel but i hear a hissing sound as if it is loosing pressure
- Real Name: Renier
2. If you unplug it your idle will go up
if not set corect also does not know proper throttle position and can be heavy on feul
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
