S14 sr20det motor with PICS pg2
Hey guys i have a full s14 sr20det motor with a bearing knock on cylinder 3 i have just redone the cylinder head a WEEK ago new valve guides,brain crower valve springs,valve stem seals,been checked for cracks and warping etc, brian crower 272' stage 3 racing camshafts,cometic head gasket, etc etc,spent 9k on the head alone. I would like to swap the hole sr20 motor with cash diffrence for a rb25. Is there any body that can help me out or know sombody that can please its my every day car so im pretty much in sh%t.
Re: S14 sr20det motor
you want to swap for rb25 as a daily eish
rat wrote:you want to swap for rb25 as a daily eish
ditto
and @K.Y.L.E - PMed :D
ditto
.. rethink that one bud
dam man, was hoping it wasnt bearing :facepalm: why not just fix it, the knock wasnt that loud, surely it wont be that expensive to cut crank and install bigger bearings. I would say you might aswell after all the work on the head, RB25 tooooo heavy on petrol man
emile vs
Real Name: emile
Post by emile vs »
Shit man, done my motor sleeves and all, started up and block crack behind sleeve. U wanne sell ur motor? $?
Pm's replied, dam emile i know what you going threw not fun at all man, it realy makes me feel like selling her but i cant there's somthing about a SX that you cannot sell no matter what.
Is a rb25 that heavy on petrol?
emile vs
Real Name: emile
Post by emile vs »
Here's guys on forum that done swop, best is to ask them. What I do know its much more fun, RB that is. Properly tuned and good ecu dnt forsee poblems. If u decide what to do I might be interested in buying ur SR20 engine. Want to show u some pics of my setup, but can't seem to do so
Besides petrole, in terms of reliable power whats better guys rb or sr
rb is a great stong motor but its not a weekend conversion or a cheap one its gonna be cheaper to strip the motor mic the bolck get the conrods and crank polished if the knock wasnt bad if it was cut weld and polished or just cut and oversize bearings, change your oil pump aswell. sounds harder but a rb conversion is a big swap and the petrol will kill you
for rb swop you will need:
Motor
Greedy style intake mani - stock doesnt clear s13 bonnet
Raditor - different outlets to SR and rb gets hot
Fans as no room for viscous
Mounts and mount brackets
Gearbox or bellhousing
If rb25 box custom crossmember
management
converters for speedo and rev counter.
Prop
wont be able to keep ac
zorst
This is before checking motor, replacing bits like rings, bearing, timing belt, clutch
Best highway fuel con was 10kms/l
Best town was 5km/l
Summary fix SR as daily, for cost of going rb you can forge your SR
I agree with rat!
sent from Ur_anus
Thanks @200sx maniac awsome info. I have diktator wasted spark managment,aluminium radiator, two 12inch electric fans, walbro fuel pump,fmic, boost pipes, and i always wanted to go rb25 guys so bare with me please lol.
poizen
Real Name: Mical Mackay
Post by poizen »
You don't have cash to fix the sr20 but you got 40-50k to do a reliable rb swap
FUEL PERFORMANCE
Post by FUEL PERFORMANCE »
SR
FUEL PERFORMANCE SA-UK-EU
HIGH FLOW SA-UK-EU
