Idle valve?
- jdm200sx
- Real Name: Ridwaan
Idle valve?
Looking for this chappie
- rat
- Car: R32
- Real Name: Rat
Idle valve?
Top one or bottom one or the whole thing that bolts onto the intake.
- jdm200sx
Re: Idle valve?
Top 1. The one that look like a long nut with plug at the end. Dus it control engine idle? Or idle up when aircon switched on?
- Real Name: Renier
Re: Idle valve?
think top one is acc valve
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
- jdm200sx
Re: Idle valve?
If I unplug it nuting happens with the idle even if I put on aircon. Cant get the idle down. It idles a 1500rpm.
- jdm200sx
Re: Idle valve?
Any suggestions how to get idle down? Its gettin quiet nerve recking hearing the engine idle so high
- rat
- Car: R32
- Real Name: Rat
Idle valve?
Make sure you don't have a vacuum leak. One of the small pipes by the intake mani.
- jdm200sx
Re: Idle valve?
Goin to remove sensors and housing tomrw to clean them out. Wil check the vac pipes aswel. I thnk aftr 20 odd years they deserve to be replaced
- Skylinefreak
- 0.5 Bar Boost
Re: Idle valve?
Have you tried adjusting the idle at the screw?
- jdm200sx
Re: Idle valve?
I have yes. With the screw fully closed its idling at 1500
- Skylinefreak
- 0.5 Bar Boost
Re: Idle valve?
Then I'd do what rat suggested, start looking for air leaks. Or maybe the "choke" / cold start auxiliary air valve is stuck open?
- jdm200sx
Re: Idle valve?
I removed all the sensors yestrday and cleaned them out,replaced all the vac lines aswell. Idle stil high. Tried to feel around intake for any leaks. Could it be intake gasket?
