Exhaust Gaskets
- Real Name: Calvin
Exhaust Gaskets
Hi guys,
I am having a problem with my s13. it seems as tho the exhaust gaskets have gone because the car makes a 'tappettie' noise when you rev the car. does anyone have have any other ideas as to what it may be, and where i can get the exhaust gaskets...
Thanks so much
Thanks so much
- Drillergy
- Real Name: Darryl
Re: Exhaust Gaskets
Is it coming from the engine or turbo?
Sounds like someones knocking.
- rat
- Car: R32
- Real Name: Rat
Exhaust Gaskets
Head to mani and turbo to mani are common problems. Cometic or Nissan for gaskets.
- Real Name: Renier
Re: Exhaust Gaskets
midas ca18de gaskets if the car is stock
between head and manufold
poizen sell copper gaskets
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
- Real Name: Calvin
Re: Exhaust Gaskets
It isnt a knock, slight ticking sound. Thanks. I tried nissan, the gaskets for mani to head and mani to turbo are R500, will try midas and see there price. So you guys definately think its the gaskets?
Re: Exhaust Gaskets
Take a pipe like a vacuum pipe or summin and move one end around the turbo and mani and mani to head flanges while the other end you keep close to your ear(while car is started) you will hear without a doubt whether it is exhaust gasses leaking.
- Real Name: Calvin
Re: Exhaust Gaskets
Will try that today.
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Re: Exhaust Gaskets
Sounds like your manifold is leaking between the head and the exh manifold. This is mostl likely because its not true any more.
Take off your mani and let it be skimmed, then refit with new gaskets. Alert spares sells the Payen gaskets which works great.
This is what i did....
- Daniel
- Real Name: Daniël
Re: Exhaust Gaskets
+1
I had those head-mani gaskets blow endless times, then I skimmed the maniford and havent had a problem again
- rat
- Car: R32
- Real Name: Rat
Re: Exhaust Gaskets
Use the nissan gasket between turbo and manifold, the cheap thin ones blow out quickly. Did this job 2 weeks ago for someone btw crap job to take the mani out good luck
- Real Name: Calvin
Re: Exhaust Gaskets
Ok cool. do you suggest that i change the mani gaskets and the turbo one at the same time?
Re: Exhaust Gaskets
Have you made sure it is the gasgets that blew? It would not be clever to fix something that you are not 100% sure is wrong.
- Real Name: Calvin
Re: Exhaust Gaskets
Ja. i put a pipe near the manifold and heard it blowing. its very difficult to determine where exactly its blowing tho. but i think its blowing from the head side....
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Re: Exhaust Gaskets
Check if you can get the steel gasket which goes between the mani and turbo, they work 100%
- Real Name: Calvin
Re: Exhaust Gaskets
Howzit guys. I managed to get the job done today with the help of my dad. We took the manifold and turbo off at the same time. the exhaust was blowing between the manifold and the head. The manifold was also quite badly warped so we had to go to the workshop and skim it. Put new gaskets on, and now it is running well. Thanks for all the advise.
