What do you guys think of the sx's handling?? Have any of you guys put it on a track,what was it like?? What mods have you done to improve the handling??
I have poly-utharene pro bushes allround from Whiteline in Aus, these made a huge difference and made the car much stiffer and allow more castor to be dialed in. Also have Koni fully adjustable dampers/shocks. A custom made front strut brace, REALLY works well and looks great. Just gotta get round to making the rear, only prob is I want it with quick release clamps incase I need to load something big. 17inch rims and tyres also help the traction problem I had. BIG front disks, cross drilled, ventilated and grooved, help the emergency stops.
HANDLING
- Daniel
- Real Name: Daniël
Powerflex make em. Surely there should be a SA distributor by now.
http://www.powerflex.co.uk/products.asp ... bmit1.y=15
- Daniel
- Real Name: Daniël
Oh found this
Worldwide Distributors - South Africa:
Turbo Network CC
P.O. Box 60159
Tableview
Cape Town
South Africa
7439
tel: +27824431887
fax: +27215567252
email: sales@turbonet.co.za
web: Turbo Network CC
Turbo Network CC
P.O. Box 60159
Tableview
Cape Town
South Africa
7439
tel: +27824431887
fax: +27215567252
I got them from www.whiteline.com, they are in Australia but do international deliveries. It comes as a bush kit, all the bushes on the chassis. These are the handling pros, they offer everything for the 180sx handling, all this stuff is proven to work.
Next I am hoping to get some adjustable blade sway bars, front and rear, also from whiteline but the freight is pricey because of the size of the boxes.
What strut braces are you guys using at the moment?? Import parts want like R1400 each, they flipping nuts. I used a E46 BMW bar becuase its the length I needed and got the mounts laser profiled bent and I welded it all together. It looks much better than the ones that import parts sell and works great.
Im not sure, But the kit has every bush you need. I have the 180sx catalogue they sent me with everything you need to make it handle properly, Not sure of how to put it on this site, sorry. Go onto that website find the code and the price. They quote on freight, VAT, everything they real good.
Anyone got bigger calipers on?? What is the price of the 350Z Brembo's??
These are the individual prices.
Front Radius rod bush kit (no caster adj.) $70
Front Swaybar link bush kit $13
Rear Lower inner control arm bush kit $90
Rear Upper inner & outer control arm bush kit (7) $79
Rear Upper inner & outer radius arm bush kit (7) $79
Rear Toe control arm bush kit (excl HICAS) $79
Swaybar chassis mount bush kit (Ø24,27mm) $20
bushes Rear Swaybar chassis mount bush kit (Ø20,22,24mm) $20
