Headlamps not closing
Spikes SX
Real Name: Nico
Post by Spikes SX »
Hi Guys,
I have a problem , my S13's headlamps are not going down(closing).
I checked my fuses in the fuse boxs and checked all the relays , none seem to be faulty.
Are there any thing that i might have missed or can look into???
The headlamps work , just not closing
Cheers
Regards
Spikes SX
"Drifting is the art of oversteer"
poizen
Real Name: Mical Mackay
Re: Headlamps not closing
Post by poizen »
put them down manually and then try again
BigKriss wrote:Image
Classic
wizard_600
Real Name: Willem
Post by wizard_600 »
I have the same problem. they open with light switch but do not close. i have closed them manually but they make the same K@K
Slap her on the ass..mind it does not slap you back. Next time she will know to keep them down.
wizard_600
Real Name: Willem
any body else have the same problem. cant figure it out. need to sort it out??
Jermaine
Real Name: jermaine
Post by Jermaine »
Hi guys,
I had the same problem, previous owner told me they just stopped closing one day. When stripped the indicator switch and saw there was a small brown plug that was not plugged in and there was no spare plug for it. Turns out the switch they had used was actually from a Sentra. I put a new switch and plugged the ill brown plug into it and it's all working now. My back lights and interior and cluster lights wre not working as well all because of this switch.
BMW 325, BMW 335, S13, RX7, Mini Cooper S Schnitzer, Golf 1 2 door and a few other cars laying around.
check the light switch on the dash might be stuffed
