Best oil for stock CA18DET?
Hi Guys, i would like to do a service since i drove the car all the way from JHB, what oil should i use?
My friend uses Castrol Edge fully synthetic with his QG15 turbo conversion, should i also use the same oil? or go for something simpler like the castrol magnetic semi synthetic?
Also i would like to change my gearbox oil, what oil and howmuch oil should i get for my gearbox? i can get a pump to pump it in aswell.
And spark plugs, should i just put in the NGK's stated in the service manual?
Thanks!
NIZAN-R
Real Name: Renier
Re: Best oil for stock CA18DET?
Post by NIZAN-R »
never use magnatech it foams in a turbo motor causing bearings to die
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
NIZAN-R wrote:never use magnatech it foams in a turbo motor causing bearings to die
Yaw im glad you told me that, so should i use the Castrol Edge fully synthetic? Ive heard its the best for turbos?
I've used Edge for many years. Although it isnt a true fully synthetic. It seemed fine though, no complaints.
Recently switched to Mobil 1
Engine oil i use.
Shell hx10 ultra Grey bottle Or castrol slx
3.6L
Gear box
Castrol 75w90 GL4
2.4L
Diff
Castrol 80w90 GL5
1.8L
Grant222
Engine: 2JZ
Real Name: Grant Jones
Post by Grant222 »
This is what i use
Engine
Gearbox
Diff
http://www.castrol.com/castrol/sectiong ... Id=6005934
aep886
Real Name: Davey
Post by aep886 »
the best oil i would said Royal Purple and Elf full synthetic^^
current vehicles...
1979 Corolla SR5
1996 S14 200sx
poizen
Real Name: Mical Mackay
Post by poizen »
I only use Fuchs full synthetic oils
SilviaS13
Club Drifter
Engine: 2JZ
Real Name: Ernest Simpson
Post by SilviaS13 »
Most of us at the track use castrol edge sport mixed with prolong engine treatment
drifterz do it slideways...
aep886
Real Name: Davey
Post by aep886 »
prolong+1
current vehicles...
1979 Corolla SR5
1996 S14 200sx
Christiaan
Post by Christiaan »
Daniel wrote: Mobil 1
+1
"Exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster."
Jeremy Clarkson
