Speedo consol
Speedo consol
In the speedo consol on the lower left hand side, there are the warning lights. There is one with no picture, does this one have no use?? Any Idea what colour the LED is?? I got a good use for it :lol: .
i dont think it has a use in south african (and therefore european) cars.
i also want to use it - to tell me when my fans are on.
but im not sure what colour it is!
what you have in mind!?!
I hope it is the same colour as the one for your brights, that nice blue.
shouldn't be a problem to replace though, is it soldered to the board or clipped down?
I think it is chipped in but I know they are hard to get.
Gary57 wrote:chipped?
chipped or clipped? chipped means soldered right?
ag - either way its no biggie!
Oh my bad I meant CLIPPED. I am only guessing here.
Ero_sennin
Post by Ero_sennin »
I have opened up mine and replace all the ilumination lights(3 in total), they are push in lights eg.
sortof like that but the stock ones are a bulb.
The small warning lights are smaller than that tho.
The one that isnt used on our cars warning lights has no globe and no turn socket either. but according to the lettering and following the tracks it is for the HI-CAS steering
the little glass nobby in the dash is just a coloured lense and I checked it was a red lense, thus using a white globe will give you a red warning light. I also had the idea of using it for something but that could be tricky as the tracks go to the wiring looms that plug in on the back of the instrument cluster.
I should've taken pics when I opened it up but hey , to late now.
EDIT:
found a pic of back o cluster
SONY Xplod inside
SR20DET Powered Red RS13
cool info ero,
guess its a biggie then!
maybe find the wires that control it, and "trick" the light into coming on and going off!
Thats what I want to do. If a trace the track and find out which pin works it then Ill cut the wire off and put my own to it.
Ero_sennin
yup perhaps that could work!
SONY Xplod inside
Are these 12v globes or LED's??
Ero_sennin
If you mean the standard one then they are 12v globes and those as in the picture are 12v leds, there are 5 hi-brite leds on the one thing. works ok, had to bend some of the leds to point at the light deflection plastic thingamajigs in the cluster
SONY Xplod inside
Just to make sure we are talking about the same lights, its the same one as your brights, the little blue one in the bottom left.
Ero_sennin
the "empty" one(same as the blue brights light) except its red.
o yes they are called "wedge" bulbs
but as I said its smaller than the ones in the pic I posted, these are size: 194 (9mm wide) wedge used as the main illumination
the ones that light up the warning light are 5mm wide wedge type
but you still have the missing wedge holder problem(red rectangle knob on back of cluster 194 wedge, the blue ones are for the 5mm ones as seen top left in pic(used for warning lights)
hope this is what you meant?
SONY Xplod inside
