Hi Guys, I have created a new threat as to work on all the individual technical issues around my car and also added some pics so that i could update as we get stuff fixed as we go along. And should be a good guide for anyone also buying or wanting to fix up a 200sx.
I have installed the Hyundai Elantra brake pads today they work perfectly product code is Fdb600-cer (ferrodo) i got them @ R365. ( will post pics later)
By this weekend ill pull out the interior and wash everything. Service the engine with all the necessary bits and also try to sort out the late boosting. I will keep you guys up to date with the fault finding should help allot of people with similar issues
So today we got all the items mostly sorted, the cam timing was out on the intake and exhaust,, but the fuel pump loses pressure when the car gets into boost
Any idea where i can get u a good pump?
Thanks! do you have pics of the wing? if it looks good ill really appreciate it
since your car is white u can use a white grout pen(by plascon) to touch up the chips untill u can have it sprayed.most big hardware stores carry them .
Just to get you updated. So i replaced the Fuel pump with a Bosch unit and set the cam timing.
The cam timing is definitely right, we checked the marks but the car seems to have even less power and shakes a bit...We did hook up a pressure gauge to the fuel line and i dont really think its the fuel pressure regulator.
What do you guys recon it migth be? how would i check if its the N/a cams in my car
What do you guys think of the car with this wing? Its the new camry wing seems to fit very well. Just need to get a way to plug those holes permanently
(To be edited)
Heres some pics of my prev ride
15.1@ Tarlton (pump gas, street setup, wheel alignment was out due to a replaced control arm
N/A 154whp&181nm torque on the wheels with pump gas ,street setup and uncorrected
Had TSW 17" mags fixed, but they where not properly sealing and cracked after a few kilo's ,instead i replaced them with Enkei Ev5's with brand new tires.
Took the whole motor out, reconned the head and fixed a couple of other items like a bent exhaust manifold ans, replaced lifters, cam belt and some pulley bearings.
Also installed a SR20DET turbo on it, but in very low on boost.
Future plans.
320D inline fuel pump, Custom exh mani and T3/4 turbo with +-70mm exhaust....just to get things started
