Price R 45,000
Address Hermanus, South Africa
Make Volkswagen
Model MK2
Body Type Hatchback
Year 1987
Kilometers 198000
Transmission Manual
Drivetrain Front-wheel drive (FWD)
Air Conditioning No
here is a bit of info:
So its a 1987 Red Volkswagen Golf GTI 16V 2.1l
There has been quite a couple of things done to this little beaut.
First off a new 9A 16V motor was bought in 2005 due to the first one going pop!
Then the motor was taken to Francois Louw for a bit of a rebuild... lets just say that there was a shitload spent on this motor and gearbox.
I'll still compile the list of things that was done.
Motor was rebuilt to a 2080cc with 10.7:1 comp ratio and gearbox has been strengthen. EFI is controlled by a Gotech MFI
Currently pushing out 135.5kw
(see dyno graph)
I'm the 4th owner of the car. The car was originally bough in 1987. The car was a 8v 1800. Motor said bye bye, so the owner then went and bought a 9A engine. sent it to Francois Louw for a complete rebuilt (see speclist below)
a Couple of other things was then done, a set of 15" Borbet Reps and Yokohama tires, Gasryder Shocks and 35mm Eibach Springs, Custom CAI induction, and a 57mm Free flow exhaust system, Slotted and drilled EBC discs in front and EBC Greenstuff pads all round. MK3 Steering Rack. The AC and powersteering was removed due to well... weight...
Engine Spec List:
Nissan ca 20 pistons
84.5mm bore
stock 9a stroke
bigger valves inlet and exhaust
Gasflowed, ported head
balanced bottom end
268 degree's intake and exhaust cams
Gearbox Strengthen - Bolt kit
Motor alone worth over R30k (check the pic attached for work on motor alone)
20000km on new motor
198000km (original) on car.
Car pretty immaculate - some panels needs to be buffed. but otherwise awesome condition. Everything still original. Even has the 16v GTI steering wheel. Interior also in awesome condition - one or two small tears in the driver side seat - no cracks on the dash ect ect. will take pics of the interior soon.
See the pics for proof.
Car looks awesome
NO JOY RIDES!
R40000 Not in a rush to sell!
Email me
0844630302
