I have been strugling to find a top mount mani with 38mm external wastegate port on it, looking for a good well made Stainless Steel mani....... Turbo Toys ones not included in what I want..... Must have correct port sises for SR20DET RWD Blacktop (Non-VVT) motor from S14a... Japanese import motor..... The one with the 2 piece intake manifold with the injectors on top..... Hopefully you may even know of one that does not need the ABS pump moved....
It's the same motor as Adam Shefer (Hope I spelt his name right) drifts with....
She is the CA that IS
(O=O)/RS13\(O=O) "if you only need one jack to raise your car, then your car isn't low enough"
"EVERYDAY I'M FLUTTERING!"
