good idea or not?!?!?!?!
gotech pro, aliminium intercooler, aliminium radiator, silicon water pipes, aliminium boost pipes... good idea or not???? i want my baby 2 run like a dream.i dont want a racing car just a smooth running beast. wat els will make her run healthier???
Best thing to do is make sure there are no underlying issues first.
Are there any problems or are you just asking for a nice healthy mod list? If so what power are you after?
Re: good idea or not?!?!?!?!
Ya everything is running hundreds.excpet that the car isn't idling perfectly.alota ppl say its coz its the standard ecu an aparently no1 in sa can tune a standard system.and aswell do just want a healthier running car.I want about 180-200kw an ova 300nm
Is it standard at the moment?
The idling could be many more things than the ECU (coilpacks, boost leak, AFM, etc)
As for your power you will need the following:
- Air Filter
- Exhaust
- FMIC
- T28 turbo
- Walbro Fuel Pump
- 1 Bar boost
- Engine management system & mapping
There are different ways of getting to that power figure but that is the route I would go.
Alluminium rad is good too, one last thing to consider is your brakes as the S13 brakes will feel very insufficient at this power.
- Air Filter
- Exhaust
- FMIC
- T28 turbo
- Walbro Fuel Pump
- 1 Bar boost
- 0.9 Bar Boost
- Engine: 2JZ
- Real Name: Grant Jones
my idle problem was that the car was running lean, it would idle then start hunting up and down al the time
Wat I do have at the month is a filter,exhaust, and a T28.wats FMIC??
- future sx owner
can stoke injector do 200wkw? just asking as i'm in the process of upgrading as well just want to kno wat i'll be needing.
Fmic is front mount intercooler
The injectors can handle up to about 200kw, anything more you need to start looking at 444's or 555's
- POWDER
- Real Name: Mike
As correct as djtreble is, I would go slightly larger on the injectors depending on if u talking fly or wheel kw.... Std Injectors and the std ECU can handle upto 1.1 bar boost (Has been covered in a previous post)
Always better to be a little rich and have room for play and future upgrades..... The only SX / CA I have seen on 210.1 RWKW has 440cc RC injectors, bosch is good make though and much cheaper....
Also, if your tuner is not all that good, then you better hope you got your motor with forgies by some stroke of luck..... Coz if you run lean, ping, ping, ping, poof......
- 0.9 Bar Boost
- Engine: 2JZ
its a bit much but the guy I bought from put in 650cc lol more than enough for the 240wkw
- POWDER
- Real Name: Mike
Hey man, u got some nice room for upgrades atleast there, that for sure..... What motor you running?Grant222 wrote:its a bit much but the guy I bought from put in 650cc lol more than enough for the 240wkw
