The previous owner f***** the current one up, it lost oil one time I drove it to JHB and back to PTA. According to the mechanic someone tried using the incorrect block with the head or something to that affectRiekert wrote:Also why you changing the motor?
Isn't it a SR20DET ?
S14 In a Pickle ...
- shiraazz
- Car: S14
Re: S14 In a Pickle ...
Driving is not my hobby, it keeps me sane
___________________________________________
Current : 1996 S14 200SX
Will be back : 1999 E39 540i
RIP : 1994 E36 325i
Ex : 2001 Daihatsu Coure 1.0
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- P3g4sus
- Club Drifter
- Car: Supra
- Engine: 2JZ
- Real Name: B.G. Smit
LOLrat wrote:thats a fwd SR20DE
i would change machie
+1
Traction is over rated.
The FWD can be put in the s-body, they even sell the kit in the USA for it. The vvl head is a much more reliable one (less moving parts) but the costs involved in the swap far outweighs the rewards. The major obstical is the dizzy position.
If you need to talk to someone, speak to someone who specialises in these cars.
PS. waste of time putting a SR20DE in there, just find a notch top RWD SR and stop messing about with different versions unless you have a very good reason for going for a different version.
- shiraazz
- Car: S14
I rather have my car they way it should be. If that guy says I should put another engine in .....djtreble wrote:The FWD can be put in the s-body, they even sell the kit in the USA for it. The vvl head is a much more reliable one (less moving parts) but the costs involved in the swap far outweighs the rewards. The major obstical is the dizzy position.
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- aep886
- Car: S14
- Real Name: Davey
rebuild your engine could be another good option if you know someone good that get the job done right^^
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
- shiraazz
- Car: S14
Another thing I forgot to mention, the engine number is filed off, I dont know how the previous guy got it through roadworthy.aep886 wrote:rebuild your engine could be another good option if you know someone good that get the job done right^^
So I rather put another engine in
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
yeah. take the plunge and get the notchtop. pull your motor and swap it. straight forward.
- aep886
- Car: S14
- Real Name: Davey
+1Riekert wrote:yeah. take the plunge and get the notchtop. pull your motor and swap it. straight forward.
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
- aep886
- Car: S14
- Real Name: Davey
there are no short cut! do it right once... or sit like Riekert
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
I second the rebuild because then you know you are getting a fresh good engine. The hardest part is finding a reputable engine builder.shiraazz wrote:I rather have my car they way it should be. If that guy says I should put another engine in .....djtreble wrote:The FWD can be put in the s-body, they even sell the kit in the USA for it. The vvl head is a much more reliable one (less moving parts) but the costs involved in the swap far outweighs the rewards. The major obstical is the dizzy position.
PS. waste of time putting a SR20DE in there, just find a notch top RWD SR and stop messing about with different versions unless you have a very good reason for going for a different version.this mechanic is peeving me off
Pity you are in pretoria as I know of a very good engine builder here in cpt.
aep886 wrote:there are no short cut! do it right once... or sit like Riekert
Hahahaha but yes... this man speaks the truth
- aep886
- Car: S14
- Real Name: Davey
Rebuild only if the block are in good shape... my bore was measure stock after 240k on it... so i did't bore and put bigger piston's
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
- aep886
- Car: S14
- Real Name: Davey
aep886 wrote:Rebuild only if the block are in good shape... my bore was measure stock after 240k on it... so i did't over bore and put bigger piston's
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
- shiraazz
- Car: S14
I might have done a rebuild if the engine number was not filed off.djtreble wrote:I second the rebuild because then you know you are getting a fresh good engine. The hardest part is finding a reputable engine builder.shiraazz wrote:I rather have my car they way it should be. If that guy says I should put another engine in .....djtreble wrote:The FWD can be put in the s-body, they even sell the kit in the USA for it. The vvl head is a much more reliable one (less moving parts) but the costs involved in the swap far outweighs the rewards. The major obstical is the dizzy position.
Im forgetting that awesome feeling being behind the wheel of my SX .....
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- shiraazz
- Car: S14
My car engine bay on 4 June 2011
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
