CA not reving above 4k
- rat
- Car: R32
- Real Name: Rat
Car is std and has stood for many years. Even in neutral it hits a limiter at 4k
A faulty engine coolant temp sensor will not put the car in limp mode.
It will only keep the car in the over-rich start up map by assuming the car's operating temp is below normal.
Have to agree, check the error codes. But if it's in limp mode it's probably the MAF.
- POWDER
- Real Name: Mike
Hey dude, check if the temp guage rises, that should thell u if it working, Djtrebble is right at assumin the MAF they can cause bad limp mode, CAS can also cause issues like that, mark the CAS for where it is then tyr advancing it a bit to see if that's the problem.
Codes will give u better idea though.....
Re:
Wrong. There are two seperate sensors:POWDER wrote:Hey dude, check if the temp guage rises, that should thell u if it working,
- Engine temp sensor with the bosch type connector that goes to the ECU
- Cluster temp sensor which has a blade conenction that goes to the back of the cluster
- POWDER
- Real Name: Mike
Re: Re:
Appologies guy, completely forgot about that.... Enzio is right there..... There is also an airtemp sensor built into ur MAF which could be messin u arround, but don't think it would cause such harsh problems, I have a spare MAF though if U would like to test the theory.....Enzio wrote:Wrong. There are two seperate sensors:POWDER wrote:Hey dude, check if the temp guage rises, that should thell u if it working,
- POWDER
- Real Name: Mike
Re: CA not reving above 4k
Will be sending some stuff down to Mical on friday or monday so if u need just shout.rat wrote:thanks will let you know
- poizen
- Real Name: Mical Mackay
Yay I can't waitPOWDER wrote:Will be sending some stuff down to Mical on friday or monday so if u need just shout.rat wrote:thanks will let you know
- rat
- Car: R32
- Real Name: Rat
no faults came up on the std ecu, cleaned the afm out. Need a working battery to start the car. Anyone know the std size for the sx?
