Wheels
Ero_sennin
i got 225/45/17 all round most of the time, no problems at all - unless you call tire rubbing the body a problem. but this only happens at near to full lock. and its cos my car is so low.
that plastic spacer thingy isnt a spacer. its an adapter to make the spigot match the hole in the center of the wheel.
dont just get any 17's. get 17's with the correct offset. or make the offset correct with some proper spacers.
my 17's run at least an inch or two from the spring cup on the shock!
Ero_sennin
- widowmaker
- Real Name: Walter
i thought so... i could tell from your avatar picture that you must have been a 1/4 spigot!!!!widowmaker wrote:my mom's half spigot
imagine what his mom looks like!!!!!
- widowmaker
- Real Name: Walter
actually, now that your mom's pic is up, she's not so bad.widowmaker wrote:you are such a meanie!
quite a MILF really!!! i reckon i could get her to smile!
hmmm...*wonders if this is going too far!*
- widowmaker
- Real Name: Walter
nothing wrong with it!!!
'cept that you will have the tiniest little strip of rubber band between the tarmac and the rim. i personally dont like extreme low profiles!!!
anyway - n1smo's 18's look fantastic on his s13!!!
you will have no problem running 18's on a standard set-up, have a standard s13 with tein springs which is aobut a 30mm drop...doesnt touch or anything, drove to CT 3 up, no problems....just got 19's for my drift car....no problems ther, but got coilovers
S13 - everything
something and something else
