Kaihatsu Factory / ROTA Wheels SA
- mario_200sx
Hey!djtreble wrote:So I have decided to display the work we do here as and when client cars are done.
FMIC with custom made hot pipe, cone filter with custom adapter plate and bracket & Slimline Westco battery:
Polybushed tension rods (the rest of the car to come):
Test fitting the White Torques in stock:
Give us a call with your requirements. 0820912639
Re: Kaihatsu Factory / ROTA Wheels SA
I am placing another ROTA order soon so get yours in now to avoid disspointment.
I am also now supplying all sorts of parts so email me with your requests to info@kaihatsu.co.za
Amazing prices such as R6800 for a full set of S13 coilovers with damper, height and camber adjustments, or R7800 for a full set of inverted damper ones with 32 way adjustable damper.
Damn!! if I didn't need a new turbo!!!djtreble wrote:I am placing another ROTA order soon so get yours in now to avoid disspointment.
- White Fang
- Real Name: Qubitt (Qbit)
Hi Djtreble
What make are those coil overs ?
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
Hi,
They are Kaihatsu Factory's own. They are made in the same factory as big brand names such as tein and hks and the quality is just as good.
Another little offering from Kaihatsu Factory, lightening your flywheel:
With ACT paddle clutch for the Kaihatsu Silvia:
That is an SR flywheel with 0.4KG's removed to mainatain a good balance between revability and torque.
We can remove as much as 2.5KG's safely out of a SR's flywheel without compromising strength if the torque doesn't bother you too much and you want a free revving SR.
Another little taster for you is this freshly painted escort from our painting partners (pre-buff and polish):
And here is the boost controller we offer for R400. We can also install it for you in any turbo car you want and set it up to the stock boost level for R300:
Mapping and engine management is also offered should you be looking for more, afterall who would install a boost controller and not want more
If you have any enquiries, don't hesitate to ask.
Replied bud, hope to see some ROTA's on your car soon!
BIIAAAATCHHHHDaniel wrote:Dropped you a PM
Final orders in today, booking collection tomorrow.
info@kaihastu.co.za
info@kaihastu.co.za
