I purchased a GT28 for my s13 CA18, will I have lag?
The difference on the compresion wheel looks scary.
I think the standard weel is 48mm and the gt28 is 54mm
I spoke to couple of guys and they said it will be fine. The guy from mr. turbo said it will be fine. Would I also have to dyno it again.
aep886 wrote:have you got a adjustable actuator?
mine GT28R from S15 with HKS actuator on the SR20det gives me 1,5bar ... but i am going to turn it down to 1,2bar
I have Started to fit the GT28.......very close fit indeed, the compresion housing is so much bigger! it clears the exhaust manifold by 1 or 2MM's
I will have to modify the acuator mounting bracket as well. not as easy as it seemed. still woried about lag...
You will only have to dyno it if your run different boost. I ran a T28 on a CA at standard boost for a while before I could fit a stage 2 map and supporting mods.
djtreble wrote:You will only have to dyno it if your run different boost. I ran a T28 on a CA at standard boost for a while before I could fit a stage 2 map and supporting mods.
Apparently the GT28 is bigger than the T28, Some even said I will have to put in bigger injectors. I want to run 0.7 / 0.8 bar boost. I think I should finish fitting it and take it for a drive. I'm running go-tech pro management.
paste this link into your browser and see if you can check the pic of the old vs new compresion wheel.
