Is drifting bad..........
- widowmaker
- Real Name: Walter
- VoodooMaster
Calibrator thanx for the great analysis of the problem that faces us. We need possible solutions to our problem. It's not gonna be much fun trying to control the itch on my foot and the fact that a bend/parking lot causes my accelerator foot to pull stiff in the same way the thought of Angenila Jollie's lip wrapped around my wartless D!ck cause a stiffy.
I already have a problem concentrating on too many things while drifting, it's my foot; the clutch; rev counter; the E-brake(handbrake); which gear I'm in; drift angle; does my hair look good enough for the photos; is the chick with that white bikini top impressed?. I don't think I'll be able to still add a Oil Temp and Oil pressure which I sill need to monitor.
Is Going FAST SIDEWAYS.
well dude. he is right you know!!! but you do what you must do. its part of maintenance. you get medicine that cures the symptoms and then you get preventative medicine. watching gauges is preventative, if you know what to look for. but its generally quite easy! get a vast array of readouts like water temp, boost, oil pressure, oil temp (engine, gearbox, diff), fuel pressure, lambda, etc, etc and you wont be sorry!!!VoodooMaster wrote: I don't think I'll be able to still add a Oil Temp and Oil pressure which I sill need to monitor.
you dont have to watch them while in a corner, but when you have time just give them a glance. if something is not right, have it sorted out! far better (and cheaper) than the medicine that cures the symptoms!!! for example, i didnt watch boost, and it was too much for my turbo. symptom = broken turbo. cure = between 4 and 11 grand. much cheaper to watch a gauge and sort the problem on the spot!
and i'm sure part of the reason my lifters are going is age. because i dont practice what i preach, and deep down i prefer ignorant bliss!!! so i reckon if i ignore the problem for long enough it will go away!!!
The Calibrator
- 0.4 Bar Boost
MAybe this what you are looking for.
Solutiuons to your drift induced problems?
Problem: Engine pumping oil out of breather
Solution: Rebuild the engine properly with top quality components
Cost: +- R20 000 to R30 000
Problem: Oil overheating
Solution: Fit a decent oil cooler
Cost: +- R2500 for quality components not cheapass Chinese stuff
Problem: Oil Surge
Solution: Fit a hi capacity baffled sump
Cost +- R2000 or R3000 once again not cheapass Chinese stuff.
Having mechanical sympathy and the ability to understand the stresses of what you are doing.
Priceless.
Problem: Oil Surge
Priceless.
heheheThe Calibrator wrote:MAybe this what you are looking for.
Problem: Oil Surge
Priceless.
Sokar wrote:To sum up, drifting is the worstest most worst thing you can do to a car, at least when "racing" a car the manufacturers made a little consession that the car might be pushed every now and again, they didnt even dream of making them drift for a living.
The biggest strain is on the chassis and suspension parts, engine does take strain, but the RPM's arent that high (myself in full drift sits at about 5k rpm and never gets close to redline, never hit limiter in a drift either)
But its not all candy and ice cream, things break, especially things that you've either neglected or "spoeg and plaked" before. Make sure your car is tip top before you start and even then expect the occasional turbo gasket or clutch to go, as I keep saying, tyres are the cheapest part of the sport
One thing I've seen myself, if you sit back and save money to be able to drift one day, you'll almost never get there, just go for it and handle the shit when it comes afterwards.
Well in reality - bushes need chaniging, regular oil changes, bolt check, nut check, wait i see them, they still fine and of course a wall and all!!!
Remember that a car is pushed to its limit when they design and develop cars, sideways, breaking, steering etc. That is why it is a good idea to have a set of upgrade suspension parts - helps alot of protection on the chassis and other vital parts
1997 Nissan 200sx S14
13B Turbo
D2 CoilOvers
PLENTY horse PoWeR - lol
13B Turbo
D2 CoilOvers
If you want to do drifting fit a dry sump. It is a lot harder to heat up 9Lt of oil than heating up our petty 3.5Lt. Also it will always give lubrication no matter if you on a straight or in a drift.Problem: Oil overheating
Problem: Oil Surge
The Calibrator
- 0.4 Bar Boost
- widowmaker
- Real Name: Walter
