1994 S13 LSD
- Real Name: Jacques
1994 S13 LSD
Hi , where can I buy a new LSD for my S13 ?
Regards
Jacques
1991 200SX S13 Charcoal
1992 200SX S13 White
1994 200SX S13 RB25 Red
Jacques
- Real Name: Renier
Re: 1994 S13 LSD
why do you need new ?
Stock lsd can be re shimed to work better than new
nissan sell the shimms ans way cheaper than a new lsd
Re: 1994 S13 LSD
more info please?Stock lsd can be re shimed to work better than new
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
- Real Name: Renier
Re: 1994 S13 LSD
http://zilvia.net/f/s-chassis/200226-sh ... -vlsd.html
http://forums.d1nz.com/viewtopic.php?t= ... 5e3afb93c8
http://www.skylinesaustralia.com/forums ... -r33-gtst/
lots of threads on the net for nissan diffs
shim it right it will be like a new and last a long time
but over shim and it wont last too long
i will be doing this to my diff untill i can get a cusco 1.5 to fit
Re: 1994 S13 LSD
mmmmmm, yes more info please.
Re: 1994 S13 LSD
great info mate , thanx alot.. i was simply not aware of this mod, did not think it was possible on a VISCOUS slip diff
edit : ah ok, i see what they are doing.. they are changing the diff preload by adding another shim.. not a bad idea, but i recon if you are going to do this , measure BOTH sides and then REPLACE both side shims with thicker, will be much kinder on the spider gears, with the same effect.
an interesting mod for sure..
edit 2 : hmmm... read a bit more, read through the FSM too, not so sure anymore if this is such a good idea.. no matter how you slice it, this WILL change how the gears heel and toe, and WILL increase diff wear.. you might be lucky and it lasts some time, or not..
in the one thread you listed there is actually one guy that did it right.. he removed and cut open the viscous clutch pack , and replaced the silicone oil with the thickest he could find, then welded it shut again..
see about middel of this page, posts by "bauerpower"
http://www.skylinesaustralia.com/forums ... e__st__140
300zx fairlady 1991
