Hi guys im looking for either a ca16de intake or ca18de intake camshaft for my det, as it has higher lift and longer duration, please if anyone has one laying around for sale or know of where i can source one locally please im very keen to try one out.
Thanks
ca16de or ca18de intake camshaft wanted
- jdm200sx
- Real Name: Ridwaan
Re: ca16de or ca18de intake camshaft wanted
That mod works like a bomb. Quicker spool up and holds boost nicely through the revs. Or just use 2 exhaust cams from DET. Will be the same as de intake cam. Specs are the same on the DET Exhaust cam and the DE intake cam
Sent from my LG-H815 using Xparent Skyblue Tapatalk 2
Thanks Ridwaan, yes for others interested det exhaust cam has same specs however the valve timing isn't exactly the same so would like De Intake Cam to keep valve timing 101percent to spec.
