- POWDER
- Real Name: Mike
OK, so after disabling everything for wash out before reassembly, I had to make a slight change to the shroud to be able to fit, also split it between the fans and changed the fan wiring so that one fan is constantly on and the other only comes in over 75deg... The rest of the pictures will speak for themselves hopefully....
Before
After
Custom made temp sensor to ensure best cold start and accurate temp maps
Wastegate adaptor sprayed with anti rust hight temp Rustolium
Mines adjustable Wastegate installed...
Shroud modified
2 X extra holes tapped into manifold for dicktator and boost gauge (new boost gauge coming tomorrow oooo, I cant wait), used hight temp Teflon lines to ensure best reaction time...
Mounted the modified radiator and intercooler in V-Mount format...
Installed Fial (Tial knock off) bov and cold boost pipe, all clamp are T-Bolt type...
Installed hot pipe and intake pipe to cold box...
And the results.... I have to admit, I'm lovin' the look...
sent from my Sony Xperia X1
Before
After
Shroud modified
- POWDER
- Real Name: Mike
Before
After
Shroud modified
Before
After
Shroud modified
- POWDER
- Real Name: Mike
I almost forgot, received my new computer for my SX... Since the last one blew up on me dire to dry joints from leaving it stored in a box in the garage, I figured this little monster will do nicely... I was told that I was the first person to buy one, never mind putting it in a car, ha ha ha...
And yes it is a fully functional desktop Pc....
4 Gigs laptop ram and a 120Gig Kingston mssd solid state hard drive for bumpy south African roads...
This with my Mini Usb keyboard and mouse, 7" touch screen and Usb dicktator is going to be epic....
- fuzz123
- 0.3 Bar Boost
- Car: S14
- Real Name: Jacobus
Awesome work there bud, this is really looking good!
How many gazillion dollars did you pay for that pc? I have the same thing in mind for our Nistune Nissan.
Buddy....that's heavy cute !!
- POWDER
- Real Name: Mike
Hey dude, p.c. Cost me just under R6k... Not cheap but going to work well...fuzz123 wrote:Awesome work there bud, this is really looking good!
- Drillergy
- Real Name: Darryl
Awesome work. Cant wait to see it.
- POWDER
- Real Name: Mike
Shot Dude'z... Appreciate the commentary
- POWDER
- Real Name: Mike
Just went to pick up my new Walboro 255lph in tank fuel pump....
Also just received my new (but second hand, thanks John) Greddy Multi-DA Gauge... Epicness....
For now it will only run boost, voltage and water temp though... But will add more sensors as and when I can afford them...
liking the v mount mike! whats your plan for the bonnet to get the air to flow right?
- Real Name: Nat Wakefield
Did someone say VENTS???
- Attachments
- gerry_x02.jpg (10.59 KiB) Viewed 14425 times
- $(KGrHqZ,!joE9UiF6-kdBPgkHMUgi!~~60_35.JPG (23.38 KiB) Viewed 14425 times
- widowmaker
- Real Name: Walter
hotter as plaasbotter
- POWDER
- Real Name: Mike
Spanks gents...
I just downloaded and am busy installing Linux Mint 16 on my pc... Gonna be fun...
