- POWDER
- Real Name: Mike
Hey guys, sorry for being so absent lately.... A small update, seems I have decided to change just about everything to try and keep spill time down as much as possible...
sent from my Sony Xperia X1
- POWDER
- Real Name: Mike
As you can see she is basically naked again.... new grocery list includes some of the following : diffirent zorst mani, new fuel rail after botched experiment, new intercooler, new wastegate, and new intake setup
O ye and had my alti and starter sorted out properly, they look so new and shimmery
- POWDER
- Real Name: Mike
I started off by checking all ports were as even as possible on the intake and zorst mani, want to make sure I have even flow on all cylinders.....
Before
After
Before
After
Before
After
Before
After
- POWDER
- Real Name: Mike
To start of I gave the intake, throttle body and many a good wash...
Ok, so as you can see, to make the new mani fit properly I had to chop quite a bit off on the water housing side
The new mani fitted.. Used all new studs with new Copper plated lock nuts... Looks so neat and shimmery....
Removed the old CAS and filled the gap with a Welsh plug, awesome idea given to me by Mr. F'rix himself, thanks Hannes... Also removed, cleaned and repositioned the dipstick tube....
- POWDER
- Real Name: Mike
Turbo now installed, also with new studs and copper coated steel lock nuts... Looking sxy now and close enough to complete for me to show the next picture as a teaser for what to expect... Hope the idea comes across nicely...
As far as I can make out, it will be the first V-mount SR install in SA... Hope I'm correct on that assumption....
- Drillergy
- Real Name: Darryl
Looking good, bud!
- POWDER
- Real Name: Mike
Shot D....
Yey, my 30mm spacers arrived today, now I can get the footprint looking epic finally and also pull the rim away from the Coilovers...
- POWDER
- Real Name: Mike
Shurrup... LolDraco wrote:Cute!!
Ok so now it's time to install the newly re furbed alti and starter...
- Drillergy
- Real Name: Darryl
So prettyPOWDER wrote:Shurrup... LolDraco wrote:Cute!!
- POWDER
- Real Name: Mike
Shot Double D...
Ok so some more progress today...
baffled the oil catch can so it actually does what is meant to... Ye I went the quick route...
Upsized the catch can nosels to suit the braided house....
Replaced the oil return pipe as the other one was a little too short for the new mani...
Stayed re doing my injector harness so there are no splices, just straight one piece setup
Cut the piping and silicone bends to size and test fit... Think it's going to look so awesome....
Good stuff buddy!
- Charlvdw
Oh, so he gets a "good stuff buddy" nogal and I get a cute??Draco wrote:Good stuff buddy!
