Spacer specs
Posted: Sat Jan 12, 2013 10:09 pm
Hello.
I need the specs on hub centric spacers for the s13 hub. 4x114.
Going 25mm front and 30mm rear. Also the spacers will bolt on to the hub then have new thread for the wheels
Any help will be awesome! Needed asap
Re: Spacer specs
Posted: Sat Jan 12, 2013 11:12 pm
Poison can make for you.
Driftworks sells them but pricey.
Re: Spacer specs
Posted: Sat Jan 12, 2013 11:26 pm
Thanx got someone who is gonna make them, a favour for a favour type deal haha. Just need the specs for him to do it.
Re: Spacer specs
Posted: Mon Jan 14, 2013 7:58 am
by Enzio
Kriek, what is the problem?
You have the PCD, the thickness and you can just measure the spigot size to be sure but is should be 66.1mm IIRC.
Re: Spacer specs
Posted: Mon Jan 14, 2013 8:07 am
Enzio wrote:Kriek, what is the problem?
Its the spigot size I needed. As I don't have something accurate to measure it with:shock:
So just need to confirm the 66.1mm size then
